Likes Likes:  4
Thanks Thanks:  3
Results 1 to 13 of 13
Thread: Rear master cylinder
    Jul 2022
    Scranton, Pennsylvania. United States
    Default Rear master cylinder
    I'm new to forum & new trike owner, if anyone could help with follow info it would be greatly appreciated.
    2009 boulevard c50 Lehman Tramp Trike, Looking for. Rear master cylinder replacement part & or part number or rebuild kit.
    As Always, Thank you!
    Dec 2012
    Santee
    The Suzuki C50 Motorcycle came from the factory with rear drum brakes and when they were converted to trikes, the manufacturer of the kit used an aftermarket master cylinder and calipers for the rear brakes. Lehman used a lot of aftermarket Harley master cylinders. Your best bet would be to take the master cylinder off and try to match it up to something aftermarket.
    Ray
    2017 Harley Triglide
    Tijuana Border
    Jul 2022
    Default Ray
    As Always,Thank you for the information.
    I was reading on this forum Lee H. Mann gave a part# GB6210 but I can't seem to find any info on it.
    Performance Machine brake parts were used as an upgrade for motorcycles, contact them and see if they can help
    https://www.performancemachine.com/c...IaAh2SEALw_wcB
    Jul 2022
    Default Jack
    As Always, Thank you!!
    Dec 2012
    Santee
    Honey Do
    Here is some more info That I have found. Lehman used Performance Machine (Harley) M/C's initially when building the Tramp trikes, but later on started using rear M/c's from the Suzuki 1400 Intruder 1987-2009 Part No. 69600-38B01. This may be what's on your trike. Don't know what year of manufacture of your kit.
    Here is a link from the archives.
    https://www.triketalk.com/forum/arch...hp/t-6552.html
    Ray
    Tijuana Border
    Aug 2020
    PA
    Default Rear brake master cylinder 2008 tramp
    Hi. Needing guidance on where to find a master cylinder for my 2008 Tramp. It is on a Suzuki. Thanks!!
    Aug 2020
    PA
    Quote Originally Posted by Sue.stevens View Post
    Hi Sue, have a look here
    https://www.ebay.com/b/Brake-Cylinde...21/bn_21473046
    Aug 2020
    PA
    Aug 2020
    PA
    Aug 2020
    PA
    Default Master cylinder for 2008 Lehman temp.
    Just wanted to put this out there. I did some more searching on some older posts. Found info that it is a HD part. No. 42446-87B just in case there are others looking. Thanks everyone for your suggestions!!
  1. Master cylinder for rear brake
    By jimmib in forum Harley Trike Conversions
    Last Post: 07-15-2020, 12:49 PM
  2. Trike rear master cylinder problem ??
    By Pre-1898 in forum Home Built Trikes
    Last Post: 10-05-2018, 11:00 PM
  3. Rear brake master cylinder reservoir idea
    By Dirtydan in forum Victory Trikes
    Last Post: 08-03-2016, 09:40 PM
  4. rear brake master cylinder spec needed
    By lardarse in forum Harley Tri Glide
    Last Post: 12-31-2013, 03:18 AM
