Likes Likes:  7
Results 1 to 18 of 18
Thread: Warped rear rotor
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    Default Warped rear rotor
    Well I found my shake. My right rear rotor is obviously warped, you can see the warp. I’m gonna see if my tire shop will turn it for me.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
    Good luck with that, I have machined a lot of rotors and flywheels
    The down side is trying to match the run out you have with the lathe is the fly in the ointment
    Solid rotors do not machine very good to begin with, let alone not knowing the run out on the hub, that said make sure you know the minimum thickness before machining
    One last thing, did you match mark the rotor to the hub before you removed the rotor?
    This can contribute to even more run out when you put it back on the hub if you did not match mark or ( index ) it
    Oct 2021
    Snow Hill NC USA
    I did not. Index them,I guess I will just wing it. I have a feeling I will be buying a new rotor. The other one looks even.
    They only have 5000 miles on them, I’m gonna take a chance.
    Quote Originally Posted by Notgrownup View Post
    I have no faith in solid rotors unless they are cross drilled to help dissipate the heat
    Good luck and let us know how it goes
    Oct 2021
    Snow Hill NC USA
    I will but I have Ebay on speed dial … they have one with 4 days shipping, I just installed EBC double sintered front pads tonight , I got tired of the organic pads not grabbing good.
    EBC are very good pads, I have used them for years, Harley brakes are poor at best IMO
    If u have access to a dial indicator you could put the rotor back on with 2 lug nuts opposite
    from each other, do a sweep and record your reading, if .003 you should be OK, if not you can index the rotor 180 degrees and try again, 50 50 chance of better run out, we used to always do a run out and re index before machining, sometimes it was a big win for the customer
    It sucks these rotors are sooooo expensive
    Oct 2021
    Snow Hill NC USA
    No shit. Of course it would be so Un Harley to use a rotor manufactured for something else already. $136 for aftermarket is freaking crazy. I have a magnetic base and a dial indicator so I will do that Jack. One thing I didn’t do when initially installed these was to make sure that the base was clean. I will check it this time. Like I said I have a feeling I will be ordering a new rotor this morning. Going on a mountain trip at the end of the month so I want to make sure I have brakes. Not gonna risk my safety for a couple hundred bucks.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I had a set of rotors turned on my buddies 09, I was standing with the guy when he turned them. They came out flat and parallel but the finish was a little rough, when he was turning them it reminded me of machining stainless steel, just kind of gummy didnt give a good finish.
    Oct 2021
    Snow Hill NC USA
    $10 a rotor, both turned a we shall see. That’s all I can say.
  11. #10
    Oct 2021
    Snow Hill NC USA
    Not a polished finish
  12. #11
    Wash it off with soapy water before install, lots of water
  13. #12
    Oct 2021
    Snow Hill NC USA
    I cleaned it up with brake cleaner. Took it for a ride. Brakes needs to be seared more, I will give it a good ride tomorrow. Too hot n humid today. Had to clean the pool and Now I’m spent.
  14. #13
    Good on you, I hope the combo of EBC pads and machined rotors works good for you
  15. #14
    Di you get a chance to bed the new pads in today?
  16. #15
    Oct 2021
    Snow Hill NC USA
    Naw, it drizzled all day. It was a shop/bourbon day.
  17. DKCustoms postbit
  18. #16
    Dec 2012
    Santee
    I seem to remember a post from years ago that had a drawing/print of (I think) of a Mustang 2?? brake rotors that were the same bolt pattern and offset as the triglide and the drawing showed how much had to be machined off each side and the outside diameter of the rotor.
    Ray
    2017 Harley Triglide
    Tijuana Border
  19. #17
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    Quote Originally Posted by Rmitchell55 View Post
    It seems to me that Fred Foster (Fearless) was looking into that. Too bad we can't ask him about it. ​RIP
    Bill
    R I P MANDY
  20. #18
    Oct 2021
    Snow Hill NC USA
    I believe I saw this as well last year. It was from a early Mustang or maverick
  1. Warped rotors
    By mlschutz in forum Roadsmith Trikes
    Owners Forum
    Last Post: 07-02-2020, 05:54 AM
  2. Warped pulsating brakes 2008 Stallion
    By Greg336 in forum Stallion Trikes
    Last Post: 03-12-2020, 02:49 PM
  3. Warped Rotors.
    By VaThumper in forum Harley Trike Conversions
    Last Post: 11-15-2012, 09:36 PM
  4. Rear brake rotor
    By GARYD in forum Harley Trike Conversions
    Last Post: 10-16-2012, 06:48 PM
  5. warped front brake rotor---not happy with HDMC
    By pcmikey in forum Harley Tri Glide
    Last Post: 10-16-2011, 06:15 AM
