My Rewaco RF1 ST won't start
I have a 2018 Rewaco RF1 ST The problem I am having is that when I turn the ignition on everything is OK but as soon as I push the brake pedal so I can start it I blow a fuse and have no power to the starter. I am looking to see if anyone else has had this problem and what they did to remedy the problem?
Mike.. Welcome to Trike Talk.����… The only thing I can suggest is to follow the wiring from the brake switch there’s probably a short it might be Rubbing against the frame .?
Thank you I really appreciate your help, I will do my best. I was hoping that there was going to be something easier than chasing wires looking for a short, you move one wire and 72 wires move and you have to try to isolate the correct wire.
Just a shot in the dark’ But check the switch and wires right at the brake pedal/ lever.??
Mike, Welcome to Trike Talk
If you can easily unplug the brake light switch, jumper the wires, if it starts and does not blow the fuse you know the switch is bad
Astro5150
Astro5150
