Breather hose on fire
Aug 28, 2020
322
456
Monaca, Pa, USA
I have a 2020 TriGlide. We were riding and smelled burning rubber. Pulled over to see my breather hose burning like a fuse . Snuffed it out with a rag. I did just fill up, but no different than I usually do. Has this ever happened to anyone? Any mods to the bike have all been done by HD. No mod to breather hose that I aware of. I bought t(e bike new 2 years age and have 8k miles.
Man - could be scary - glad you caught that
I have a 2019....And the ''Stock'' breeder hose is inside the air cleaner housing, And in order to see the hose i would have to take the air cleaner cover off first with a large Allen key...Are we thinking of the same hose...:Shrug:...
Do you mean the gas tank vent hose ?
There’s a big difference between vent hose and breather hose…!
The fuel tank has a vent hose also, if it is not routed correctly it could rub on the belt, enuff gas vapors could possibly ignite that hose
He said He just Filled Up ???
Until the OP gives more info we are guessing at best
From the U.S. Army FM- UrScrD rev. B on diagnosing mechanical failures under field conditions: "Always revert back to the last individual(s) that worked on that piece of equipment."
Also the gas tank vent hose is running down right side of frame? All work has been done by HD. Anyone with a 2020 TriGlide have fuel tank breather hose on rt side? Thanks
Here is what the fuel line vent looks like on your trike, # 5 and 6
That cooling fan occupies a space that could push against the vent tube IIRC, that perhaps could have been the start of the problem, is that the area where the fire was?
stumphumper
stumphumper
