Likes Likes:  5
Thanks Thanks:  2
Results 1 to 8 of 8
Thread: M8 Trike Owners Check Plug Wire
    Default M8 Trike Owners Check Plug Wire
    Check to make sure your plug wires are attached to the part of the frame behind the rear cylinder, this is my second M8 I have owned where the wires were not attached properly from the factory, 1 wire shows signs of the outer jacket having a burn mark
    Jack......I was going to ask you if you could post a picture of the spot where the attachment should be made.....But i'm a little enbarrassed because i can't no matter how many time's i tried to post a picture over the years and failed..........
    I am not very camera savvy, my wife is so I will try to get her to snap a picture
    Give her a Kiss for me..................
    Here is a video showing how to change the wires, @ about 6:19 on the video you can clearly see where the wires attach to the backbone part of the frame
    If you look at the area under the ( front) seat, from the left side of your bike you get a straight shot @ seeing the wires and how they clip to the frame
Size:  144.8 KBName:  Resized_20220718_174922.jpeg
    These picture are not the best
    Now I’m confused as a goat on Astroturf…. Had the four grandkids over most of the day so I’m a little zonked out right now I feel like I went down the road with one wheel off and the axle dragging… I’ll try to look at the pictures later tonight , Maybe I can figure it out then..?
    The top picture is the right side view, the bottom picture is the left side view
  1. Spark plug wire resistence
    By keikat2 in forum Harley Tri Glide
    Last Post: 07-29-2019, 02:28 PM
  2. Harley Tank rubs Groove into Screamin Eagle 10MM Plug Wire!
    By Rooster57 in forum Harley Tri Glide
    Last Post: 04-07-2018, 11:03 AM
  3. Front spark plug wire 2014
    By Moe55 in forum Harley Tri Glide
    Last Post: 05-24-2015, 04:59 PM
  4. Front plug wire insulation & gas tank
    By Beorn of Ga in forum Harley Trike Conversions
    Last Post: 07-08-2014, 06:01 PM
  5. Change 5-round plug-in to 4-flat plug in for trailer
    By BinIdaho in forum Harley Trike Conversions
    Last Post: 02-26-2013, 11:42 PM
