Likes Likes:  18
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
Thread: 2014 rear brakes
  1. #21
    20+ Posts
    Mar 2022
    Wilson, NC USA
    Can you get the stainless steel pieces that the pads slide on separate? Some of the "spring wings" are missing.
    Also as info my 2014 rear caliper pistons are the push in kind.
  2. #22
    Quote Originally Posted by 14triglide View Post
    Did the pads not come with new clips?
    I cleaned up the old ones on my 15 FLRT and used them over, the EBC pads I got did not come with the new clips
    Good to see your pistons do not screw in, that makes the job easier
  3. #23
    Here is the HD part number
    41300046
    SPRING PAD
  4. #24
    20+ Posts
    Mar 2022
    Wilson, NC USA
    New pads did, but old pads and rotors are fine. Harley can order new spring pads @ $22 a piece. At that price I can buy a whole brake kit for $77.
  5. #25
    20+ Posts
    Mar 2022
    Wilson, NC USA
    As info: 35 ft/lbs on caliper bracket bolts and 32 ft/lbs on caliper pin/slider bolts.
  7. #26
    20+ Posts
    Mar 2022
    Wilson, NC USA
    Would like to thank everyone for your help and knowledge concerning my rear brakes.
  1. 2014 Tri Glide rear brakes, HELP !!
    By Chilltrike in forum Harley Tri Glide
    Last Post: 08-02-2021, 05:57 AM
  2. no rear brakes on 2011 Vision Crossbow rear end.
    By Buellee in forum Lehman Trike
    Last Post: 05-22-2019, 10:28 PM
  3. Rear disc brakes, VERY HARD pedal, weak brakes????
    By TrikerDoone in forum VW Powered Trikes
    Last Post: 05-29-2016, 12:14 PM
  4. Help, 2014 TG Rear Brakes
    By Jlbhdtrike in forum Harley Trike Conversions
    Last Post: 03-05-2015, 10:44 AM
  5. Rear brakes on Harley 2014 Trike
    By martyjk in forum Harley Tri Glide
    Last Post: 08-22-2014, 02:44 PM
