LD-Ordie2Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie2LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Results 1 to 5 of 5
Thread: Fork oil amount
    5+ Posts Keystone742's Avatar
    Feb 2021
    cuyahoga falls, ohio, usa
    Default Fork oil amount
    I'm changing a bad fork seal on my 1999 GL1500 SE with a Roadsmith Ultimate trike kit which I believe has a 4' Roadsmith rake kit. Can anyone tell me the amount of fork oil I need in each tube? I don't know if the rake kit uses the same amount or more than Honda did on the OEM forks. Also, being a trike does it matter what oil weight I use? On my 1100 and 1200 I usually use ATF. Thanks.
  2. Roadsmith banner
  3. #2
    250+ Posts
    Jan 2012
    oz
    Quote Originally Posted by Keystone742 View Post
    I'd call Roadsmith & get the correct info 800.331.0705
  4. #3
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    It still has the stock forks so normal fill levels and just like before different weights can give you different feel.It can be played with to get things to your liking.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
  5. #4
    Feb 2021
    God to know! Thanks
  6. #5
    30+ Posts Ghost Rider 2's Avatar
    Sep 2022
    Downs, Illinois USA
    I rebuilt my wife RS trike month ago. Installed new set of Progressive springs in it. There was a chart I found that said the fluid was supposed to be so many inches from the top. Can't remember for sure but number was close to 5".
  1. A small amount of restored faith in humanity.
    By Mykneesbehurtin in forum General Discussion
    Last Post: 02-04-2022, 04:24 PM
  2. Fork Brace or no Fork Brace.
    By cScjhb in forum Honda Trikes
    Last Post: 01-15-2021, 06:32 AM
  3. Amount of rear end oil.
    By cavie in forum General Discussion
    Last Post: 02-02-2016, 12:00 PM
  4. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
  5. Amount of usable gas in tank
    By darrell moore in forum General Discussion
    Last Post: 01-28-2010, 12:31 AM
