14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  5
Results 1 to 14 of 14
Thread: Trike won't start
    5+ Posts
    Aug 2022
    West union wv usa
    Default Trike won't start
    Got my 2008 goldwing with 33000 miles trike 3 months ago haven't got to ride much yet went to start today turned over fine gut wouldn't start acts like no fire check fuses they were fine its has never had this problem before just don't know if it is something with kit or something else it's a csc viper kit any idea where to start thanks
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Pull a spark plug . Wet … no spark . Dry…… no fuel .
    It’s a start anyway , not guaranteed !
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by Rogerinwv View Post
    Roger .....Welcome To Trike-Talk..........Setting for 3 months..Throw a charge on the battery, And maybe also check to see if you have enough gas in the tank??
    2019 Tri-Glide.......
    5+ Posts
    Aug 2022
    West union wv usa
    Battery is charged and good pulled plug there is no spark I think it has something to do with the wiring due to the kit installed going to try to talk to the installer tomorrow maybe they can help
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Crazy as it sounds check and see if the kill switch is in the position…All when the trike was a two wheeler there’s a kill switch on the kickstand and sometimes the installer will just tape it back and not disconnect it?..
  6. #6
    Jun 2008
    Lovington, NM, U.S.A.
    Check the kill switch on the right side cluster on the handlebar, could have been bumped and now off.
    Retired trike builder
  7. #7
    5+ Posts
    Aug 2022
    West union wv usa
    I am not sure but I think the wings will not even crank in the kick stand switch is the problem will try more tomorrow thanks
  8. #8
    Jun 2008
    Put the trike in neutral and hold the clutch lever in.
  9. #9
    Contributing Member ROAD DOG's Avatar
    Jan 2009
    MA,
    I would pull the seat off & look for sign's of Mice in there eating up the wires ? You rode it to were you parked it ? Can you here the fuel pump run when you turn the key on ?
  10. #10
    5+ Posts
    Aug 2022
    West union wv usa
    Took black cover off and move crank shaft sensor wire bike fired right up didn't look bad Clean it up seem to be running fine
  11. #11
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
  12. #12
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Good for you to find the problem and to get it running!
    Thanks for the post as it might help others down the road.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
  13. #13
    5+ Posts
    Aug 2022
    West union wv usa
    We like trying to fix stuff our self to many times when we take them to garages they just throw parts on and charge a arm and leg and still don't fix the problem. They could learn more doing research on line hopefully my problem might help someone else.thanks
  14. #14
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I know this sounds demeaning but check the kill switch
  1. Trike won't start in gear with parking brake on
    By bowelder in forum Harley Tri Glide
    Last Post: 12-03-2016, 09:37 PM
  2. Trike won't start in neutral
    By Huelshorst in forum Harley Trike Conversions
    Last Post: 06-28-2013, 06:28 PM
  3. Trike won't start
    By rwhgme in forum Harley Trike Conversions
    Last Post: 11-05-2012, 02:53 PM
  4. Trike Won't Start??
    By BinIdaho in forum Harley Tri Glide
    Last Post: 09-08-2012, 11:17 AM
  5. Trike won't start
    By clo in forum Honda Trikes
    Last Post: 08-14-2012, 08:25 PM
