Likes Likes:  1
Thanks Thanks:  1
Results 1 to 13 of 13
Thread: Champion GL1800 IRS Trike Shock Question
    20+ Posts JimsGL1800's Avatar
    Jan 2021
    Vicksburg, Michigan USA
    Default Champion GL1800 IRS Trike Shock Question
    I have a 2012 Gl1800 and one of the rear shocks is starting to leak a little and I would like to know if anyone has replaced one of these yet with something other than one from Champion.
    20+ Posts
    Feb 2022
    tucson az usa
    Default shocks
    Quote Originally Posted by JimsGL1800 View Post
    I have some for IRS that are New from Champion.
    30+ Posts Ramnight's Avatar
    Jan 2021
    Quote Originally Posted by Orangekrate View Post
    Can you tell me which springs are on them?
    20+ Posts
    Feb 2022
    tucson az usa
    Default shocks
    Champion started with
    20+ Posts
    Feb 2022
    tucson az usa
    ALSO...
    Jan 2021
    ALSO.....check Kalamazoo CL MotorcycleParts
    Great Thank you
    Jan 2021
    Champion started with Blue springs. Then they did yellow like yours and a few years ago they switched to the ICON that have Red springs. They all fit the IRS. Check My post you (JimsGL1800) replied to about adjustments a couple weeks ago 8/28. there's a pic of them. That's what's available now from Champion. Let me know what you think.
    Ok, Thank you for the information.
    20+ Posts
    Feb 2022
    tucson az usa
    So are these something you're interested in?
    20+ Posts
    Feb 2022
    tucson az usa
    Default Replacement shocks .. coil overs
    Hello Jim. Happy New Year! Did you ever get your shock situation resolved? I still have the New pair we discussed but never heard anything more from you .
    1+ Posts RonKamCH47D's Avatar
    Jan 2023
    Apple VAlley
    Default Lube & Ride
    Click image for larger version.
Name:	2010 GL1800.jpg
    2 questions, I bought this little girl last year and love it. Question since you guys are talking suspension...This is a Champion conversion with IRS. Honestly coming off a two wheeler I find the ride very "rigid". Is that typical or should the ride be smooth? What lube am I buying to lube the drive shaft U-joints?
    Ron…Welcome to Trike Talk..����.With 3 wheels on the ground the ride will never be as smooth as a 2 wheel bike….With 3 wheels one will always hit a pothole whereas with 2 wheels you can avoid them..
    Jan 2021
    Thank you, Sorry for the delay on replying to this massage. I sent you a message back in January and never heard back from you, so I figured someone else already purchased them. I did more research on mine after going to a car wash on a nice day and really cleaning the rear end and apparently the previous owner of the bike has soaked the shocks with some kind of oil to free up the adjusters. After the shocks were clean, I have not seen any oil leaking out of them in over 300 miles.
    But I will keep you in mind in case I decide to have a backup pair.
    20+ Posts
    Feb 2022
    tucson az usa
    Hi Jim, Yes I do still have them and have been going to put them on ebay but haven't as of yet. I don't check this often but let me know if you would like them I'm sure we could work something out.
    Thanks Rod
    Best way to contact me would be Text520 27985o9 for some reason PM does not work for me.
  1. Champion Trike GL1800 Shock Replacement Question
    By Dave M in forum Honda Trikes
    Last Post: 06-20-2021, 08:53 PM
  2. Champion IRS Shock Absorbers
    By Bush Hog in forum Champion Trike
    Last Post: 04-25-2021, 05:33 PM
  3. Champion IRS Shock Adjustment Question
    By Ramnight in forum Champion Trike
    Last Post: 02-22-2021, 01:20 AM
  4. Roadsmith irs vs Motor Trike irs
    By david1144 in forum Honda Trikes
    Last Post: 08-31-2015, 10:52 PM
  5. Question on adjusting shocks on Champion IRS kit
    By ColoNavy in forum Honda Trikes
    Last Post: 06-30-2015, 06:38 AM
