El Lobo
30+ Posts
Hello Gents
So this is going to be a long story. So my brother in law and I were riding to the memorial day run in Red river NM, when we arrived in Taos we pulled into a gas station, my brother in law noticed that his 2019 Tri-glide was leaking anti freeze from the left side of the Trike. We checked the reservoir and it was empty, having no anti freeze we added water to the reservoir and started off again, we rode about 2 miles when the engine coolant temperature light came on, we pulled into the nearest gas station and checked the coolant reservoir again the reservoir was empty so we filled the reservoir again and purged the radiator to clear out any air from the system. We let the trike run to make sure it would not over heat again; the trike had been running for about 4 minutes when all of the coolant just poured out of the left side, We had to get the trike towed back home. MY brother in law later on had the trike towed to his Harley certified mechanic.( he will not have any work done at the Santa Fe Harley Shop) We had thought that maybe the water pump had gone out, or a water hose had busted. When the mechanic checked the trike, he found that Harley had not installed a clamp on one of the hoses. Causing the hose to come loose. SO MUCH FOR QUALITY CONTROL!!!!
Ride safe.
El Lobo
Ride safe.
El Lobo
