ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Results 1 to 6 of 6
Thread: Steering is too hard on 2010 goldwing with roadsmith conversion
    Aug 2022
    Florence
    Default Steering is too hard on 2010 goldwing with roadsmith conversion
    I am new to a trike and the steering I think is way too hard roadsmith raked front when it was triked bike only has 7000 miles on it have tried different tire pressure and air sup.ride but has not done a lot of good, any suggestions. I have rode 2 wheelers since 1967 don't think I am going to like riding trike.
  2. Roadsmith banner
  3. #2
    250+ Posts
    Jan 2012
    oz
    Give Road Smith a call and see what they suggest
  4. #3
    Jimmy a slight possibility that the steering stem was over torqued. The torque should be 40lbs. One test is slightly lift the front so front tire can just swing but not higher. Pull it all the way in one direction. Let go and see if it swings. It should swing back most of the way in the other direction. If it does not move or moves less than back to Stright I would bet on the over tightened stem.
  5. #4
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Boomerang View Post
    how many degrees in the tree?
  6. #5
    200+ Posts
    Nov 2010
    CALHAN COL.
    Default Easie fix
    Call Randy and have him get you a 6% rake KIT
    Sep 2016
    Springfield, Mass. USA
    We haven't heard anything more from the poster............ How did you make out with the hard steer'n on your trike??? and what did you do to help out with your problem or concern??
    I sure there's many other's on this board that would be interested in learn'n or try'n, cause they also have the same problem(s)
    9/23/22
  1. Hard steering.
    By Clevelandpat in forum Harley Trike Conversions
    Last Post: 03-01-2022, 02:30 PM
  2. Hydraulic clutch too hard to pull
    By Huelshorst in forum Harley Tri Glide
    Last Post: 03-17-2016, 11:49 AM
  3. 2015 TG clutch pulls too hard
    Last Post: 08-14-2015, 08:52 PM
  4. need steering dampener for 2010 Roadglide with Motor Trike conversion
    By Sloride in forum Harley Trike Conversions
    Last Post: 04-28-2015, 08:13 PM
  5. The ride's too hard
    By gareth323 in forum General Discussion
    Last Post: 07-20-2010, 03:49 PM
