ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Results 1 to 4 of 4
Thread: rubber pad for brake pedal on gl1800
    Jun 2022
    COOPER, tx, USA
    Default rubber pad for brake pedal on gl1800
    I would like to raise the height of my brake pedal, looking for a rubber pad something like a emergency brake pad. Anyone ever do this. I have a gl1800 with a motor trike conversion.
    Feb 2008
    Shippensburg, Pa
    Quote Originally Posted by ontheroad View Post
    if your brake pedal is like every other brake pedal on every bike iv'e ever worked on. there should be an adjustable rod between the pedal and the master cyl. this rod will have jamb nuts. keep in mind if you adjust that rod to the desired position for the brake pedal then you will more than likely need to adjust the brake switch. which is also easy. the switch will be plastic with a plastic nut that will adjust it.
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    1
    if memory serves me correctly the jam nut is a 12 mm and the adjusting nut is a 10 mm and could be partially concealed by the rubber boot.
    2019 Goldwing CSC
    Jun 2022
    COOPER, tx, USA
    Thanks for the information, very good info. I will give that a try.
  1. Rubber pad on Floorboard
    By grandpawj in forum General Discussion
    Last Post: 09-02-2019, 05:44 AM
  2. just a pic of '09 t/g rear brake pad
    By eagle1 in forum Harley Tri Glide
    Last Post: 08-21-2012, 07:22 PM
  3. Front Brake Pad Replacement
    By Gorilla in forum Stallion Trikes
    Last Post: 07-11-2011, 11:07 PM
