Likes Likes:  11
Thanks Thanks:  3
Results 1 to 14 of 14
Thread: Front tire wear
    20+ Posts
    Mar 2022
    Wilson, NC USA
    Default Front tire wear
    Hello everyone,
    went to Maggie Valley recently and put about 1000 miles on trike. Upon returning home noticed cupping on front tire. I checked and adjusted pressures before we left. To all who are in Maggie this weekend for holiday when you get home check your front tire and post how yours looks and any suggestions.
    P.S. found out my trike has a recall. Go to the Harley site and enter your VIN #.
    Quote Originally Posted by 14triglide View Post
    Hello everyone,
    Have you notice any vibration at a given speed if so the tire might be out of balance??
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    I've always had good luck on "how' my front trike tires wear, the issue has always been they wear out between 14,000 and 16,000 miles. I just went over 40,000 miles on my 2019 and I will need my third front tire in another month or two.
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
    20+ Posts
    Mar 2022
    Wilson, NC USA
    When balancing your front tire what do you prefer? Stick on lead weights, balancing beads, or something else, like Ride on?
    Also what kind of tire pressure do y'all run in the front tire when it's 90 degrees plus outside?
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    I run 36 psi in front.
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    I just did 1350 miles in the WV hills pretty aggressive and some interstate with a brand new D402 mounted backwards and it still looks and feels great.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
    20+ Posts
    Mar 2022
    Wilson, NC USA
    Quote Originally Posted by Notgrownup View Post
    Notgrownup, What pressure do you run in the front tire and what balancing method do you use? Thanks
    300+ Posts
    florissant
    I run 22 lbs. in the rear tires and 36in the front. I do run Rise-On in my tires too. i think it is great balancer and sealer too.
    hardheaded
    Oct 2021
    Snow Hill NC USA
    Weight balanced for now but debating putting Rideon gel in . I run 36 in the front. I run 25 lbs in the back.
  11. #10
    Dec 2021
    merritt island
    Hello everyone,
    What tire?
    What pressure?
  12. #11
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    22 in rear & 36 front.. I use Dyna beads for yrs. Tried Ride-On once & when guy changed the tire ,it was a total mess for him to clean that stuff out before he could mount the new tire. Never again ..
  13. #12
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    I've used the Dynamic Bead Balance System for years. Dozens and dozens of tires no one ever brought one back for a rebalance.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
  14. #13
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Ive used ride on and it worked well but yes messy. Since I got my No- Mar machine Ive gone back to wheel weights.
  15. #14
    20+ Posts
    Mar 2022
    Wilson, NC USA
    Davekp, Front OEM tire, I run 36 psi, rear OEM tire 205/65/15, I run 22psi.
  1. Front tire wear
    By Daytona in forum Can Am Spyder Trikes
    Last Post: 05-25-2017, 08:56 AM
  2. Front tire wear after installing a trike kit
    By Cecil K5LO in forum BMW Trikes
    Last Post: 04-21-2017, 04:56 PM
  3. Front Tire Wear
    By tis in forum Harley Tri Glide
    Last Post: 09-26-2016, 09:48 AM
  4. Front tire wear
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 01-13-2012, 06:19 PM
  5. Front tire wear
    By hitime in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-21-2010, 02:18 PM
