Likes Likes:  7
Thanks Thanks:  7
Results 1 to 10 of 10
Thread: 6-speed noise
    Sep 2022
    REDCLIFF AB CANADA
    Default 6-speed noise
    Does anyone know how to stop a 6-speed tranny from sounding like it's throwing a gear right through the side casing when you shift; especially from neutral to first?
    Also does baker or any other aftermarket tranny makers sell a quieter set of replacement gears or even a complete tranny.
    Can I down grade to a 5-speed on my 103? Of all the Harleys Iv'e owned (this is my first twinky and 6-speed) Iv'e never had a noisy tranny.
    Quote Originally Posted by elvis View Post
    Hank...Welcome to Trike-Talk........If you are talking about the Harley Clunk' Neutral to First...Every Harley I've had (4) of them had the Cluck .. Part of the Harley charm i guess?
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    From cold , neutral to first , the dreaded Harley clunk !
    After the initial warm up , I shut down , put in first , clutch disingauged, restart then go .
    Trans is quiet with out any clunks after warm up .
    Question , why would you want to downgrade to a 5 speed
    welcome Hank Try changing to a synthetic gear oil. One of the brands like redline or? It will make a difference.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    On my 17 with a six speed I pull the clutch in and wait at least 10-15 seconds before dropping in gear. This allows the clutch basket to slow down just enough to avoid the CLUNK. At least 90% of the time, even on cold idle.
    Try blipping the throttle ( with clutch pulled in) before shifting into first, this will help to unstick the clutch plates
    All HD trannies are constant mesh, this is part of the mystery clunk, you will never get rid of it completely
    What do you use in the primary and tranny for lube?
    Use a good tranny fluid and primary fluid also
    Welcome to Trike Talk and your first post
    The Harley Clunk has a good use’ When some nimrods stand around my Trike and want to keep on talking about it and want to get out of there I just Clunk it into gear and everybody jumps out of my way…😉😁..
    What year and model is your trike?
    Hydraulic or cable clutch?
    Sep 2022
    REDCLIFF AB CANADA
    Quote Originally Posted by jack klarich View Post
    what year and model is your trike?
    2015 freewheeler with hydraulic clutch
    Has the clutch fluid ever been flushed?
    Every 2 years for sure, if you are not sure, get it done
  1. High speed noise
    By Kentosh in forum Honda Trikes
    Last Post: 05-18-2016, 01:18 PM
  2. 6-Speed vs. 5-Speed Fuel Mileage
    By 1550vt in forum Honda Trikes
    Last Post: 03-08-2014, 06:36 AM
  3. New Rattling Noise???
    By Randylic in forum Honda Trikes
    Last Post: 08-10-2009, 08:35 PM
  4. tire noise
    By wingman in forum Tires, Wheels, Brakes, Front End
    Last Post: 06-10-2008, 08:20 PM
  5. cb radio noise
    By rollinthunder in forum Accessories
    Last Post: 02-24-2008, 05:06 PM
