Likes Likes:  14
Thanks Thanks:  7
Results 1 to 19 of 19
Thread: Anybody Use a Skywoosh Cooling Pad on Their Tri? Looking for Real World Reviews!
    150+ Posts hydraglide's Avatar
    Dec 2021
    Woodridge,Il USA
    Default Anybody Use a Skywoosh Cooling Pad on Their Tri? Looking for Real World Reviews!
    It’s been a great summer so far with over 7k in the saddle on my Tri Glide. I’ve rediscovered the joy of being in the wind again!
    However, the one “area” I’d like to improve on (literally) is between me and my Road Zeppelin seat… cooling wise.
    The saddle itself is comfortable but on long,hot days… I find myself “lifting off” more than I’d like to get some air circulation going in an attempt to cool off.
    That’s where the Skywoosh cooling pad (the big one for touring saddles) caught my eye while visiting J&P Cycles the other day in Anamosa.
    Dimensions are perfect, and in theory it seems like it could help (gel pad with cooling mesh vents for air flow). But before I jump I wanted to hear from you all and see what you might have experienced.
    I’m open to other suggestions too so fire away!
    Live Everyday Like It's Your Last... Because One Day It Will Be...
    2021 Billiard Red Tri-Glide • 1999 Ultra Classic - Stage 2, 6 Speed (Gone) • 1995 Softail Nostalgia (Gone) • 1977 Superglide - Chopped (Gone)
    • 1976 Liberty Edition Sportster (Gone) • 1949 Hydraglide Panhead - Fully Restored (Gone)
    100+ Posts Longbeard71's Avatar
    Nov 2018
    Talbott tn usa
    Sheepskin seat cover great in summer and winter.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    For the first time in 50 years of riding, I used a sheep skin for our long distance ride this year and it worked great. 400–500-mile days were never an issue.
    Just Killing Time...
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    Bead seat lifts you up-off the immediate surface allowing air to circulate between and also provides breakup of pressure. Some people like them, others don’t but the air circulation is real with them.
    You can find them from around $13.00 and up… just do a google for motorcycle bead seat.
    450+ Posts arnie's Avatar
    Dec 2011
    camp grove,il.usa
    I have the beads, h-d air cushion, & sheepskin. My pick is the wood beads. I have taken all 3 with me on long trips & i always end up using the beads the most.
  6. DKCustoms postbit
  7. #6
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Quote Originally Posted by Longbeard71 View Post
    I bought one from Alaska Leathers after reading about them in forums. I purchased it for a previous bike, the bike is gone, but I kept the sheepskin cover for the new bike. If it gives a more comfortable ride in Texas in August; it’s likely to help anywhere this side of hell! 😎
  8. #7
    Dec 2021
    Woodridge,Il USA
    Sheepskin, beads... both interesting options and worth checking out. Sheepskin keeps your bottom cool and dry(er)? I can see where the beads would help with airflow.
    But I have to believe there has to be at least a couple of you Tri-Glider's out there that used/tried either the Skwoosh seat pad or similar made from mesh... I see even Harley sells one (The "Circulator"), but, they don't fit (or so they say the don't fit) the Zeppelin seat. Go figure.
    Don't be shy... ..lemme know what your experience has been!
    Thanks all!
  9. #8
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    Although I mentioned the beads earlier, my preference for years has been the Air Hawk air cushion. By itself it doesn’t provide for the flow of air as does the bead seat but I have found it to be all I need for pressure comfort.. in hot or cold temps.
    But if its absolute air circulation you are looking for the bead seat is a good choice. I have also used the bead seat underneath the Air Hawk on a long hot summer trip and I could feel the cooler temp difference provided by the bead seat.
  10. #9
    150+ Posts
    Apr 2018
    Cordes Lakes, AZ
    ^^^^^^^^^^^THIS^^^^^^^^^^^^^
  11. #10
    10+ Posts
    Aug 2020
    Oskaloosa, IA, USA
    I use a similar product from PPI - a gel seat pad with mesh cover. You can feel the ventilation when you hit highway speeds. I've not yet tried the sheep skin but am quite curious about it. The gel seat pad I went with came in either mesh covered or sheep skin covered. It definitely helps.
    The supplied mounting straps could be better IMO. I found them difficult to install. I ended up using a velcro strap attached under the seat and through a mini carabiner on either side of the cushion. The straps tuck in out of sight when not in use.
    Quote Originally Posted by hydraglide View Post
  12. #11
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Default Epa recalling beaded seats 🛑
    Speaking of the wood bead seat pads the EPA is issuing a recall on them it seems to be That the beads made from the wood if the Ba’ba tree native to India and a danger to the environment once the lacker coating of wears off it leaches high levels of methane gas ..Walmart the largest seller of wood bead seat pads is fighting the recall.. Walmarts argument is that the wood itself is not the problem Rather the problem is the person sitting on the seat pad is the one leaching the high levels of methane gas…
    2019 Tri-Glide.......
  13. #12
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I use a sheepskin with an airhawk below it.
    Sheepskin is cooler in the summer and warmer in the winter.
    I've tried gel pads, don't find them as compliant as the air hawk.
    Also, the big con on the gel pads for me is that they can get really hot when parked in the sun for any period of time and really cold when parked in the cold for a period of time.
    The good thing is that gel pads will hold their temperature for quite a while, the bad thing is that gel pads will hold their temperature for quite a while.
    www.DKCustom.com
  14. #13
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    I dont like gel anything that comes in contact with any part of me. I put gel insoles in my work boots. By midday I didnt like the feeling. Like your socks are wet but its still dry. Swamp butt( feet?) is a another way of puttting it I guess. Whatever pad one prefers dont forget what type of pants your wearing. Sitting for hours( try 10- 11 hours in a semi truck) on a bike in the hot sun will prove that heat buildup in those pants becomes uncomfortable. Ive found Diamond Gusset motorcycle jeans very comfortable. American made but pricey.The crotch gusset allows air to flow where its ..um...really needed.
  15. #14
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Old Road Dog View Post
    I don’t know but….For me nothing comes between me and my Calvins😉😉..
  16. #15
    Trike Talk Executive Chef
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Airhawk Pad Would Be A Good Choice And Can Be Readjusted For Your Needs.........
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Member Patriot Guard Riders
  17. DKCustoms postbit
  18. #16
    150+ Posts windsurfed's Avatar
    Jul 2020
    Spokane WA USA
    So many different opinions! Can't we all just get along? I have tried many different cushions. I prefer Beads myself. However, since I bought my Tri Glide I haven't used anything with my stock seat because it is rather comfortable all by itself. A day ride would constitute around 275 miles on average. Unually by the end of the day I would start day dreaming of the beads.
    Stupid is a choice
    Dumb is not a choice
    Stupid can be fixed
    Dumb cannot be fixed.
  19. #17
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    I like the Alaska sheepskin, I just returned from a 1350 mile 4 day ride and I did like it, I have 2 air hawk pads for me and Mrs Notgrownup. I also have a HD Circulator pad , it also works very well. Never tried the beads yet but I am now breaking in my Ultimate tallboy seat pretty good.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
  20. #18
    Dec 2021
    Woodridge,Il USA
    Well, update... I went with adding the Air Hawk pad and it made quite a difference, comfort and cooling wise! Followed the instructions and added just enough "air" to let the bladders adjust to my riding position as I adjusted myself or adjusted the Harley Air Zeppelin bladders. I couldn't believe the added increase in comfort. Quite noticeable now if I forget to use the Air Hawk.
    Next riding season I will try adding the Alaska Leather Sheepskin Butt Pad over the Air Hawk.
    Anyone using the Alaska Pad solely on the riders portion of the seat and not the entire seat? If so, can it be used effectively without using the straps?
    Already looking forward to getting back out next spring!!
  21. #19
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    I use the Alaska Leather sheepskin on my Tri, but I use the straps. Very comfortable for me
  1. Replies: 5
    Last Post: 06-14-2021, 03:28 PM
  2. Has anybody upgraded their boom box radio--2014 and above
    By Trampas in forum Harley Tri Glide
    Last Post: 10-07-2019, 08:14 AM
  3. Anybody Ship Their Trike
    By KJB in forum Harley Tri Glide
    Last Post: 01-28-2017, 02:49 PM
  4. Replies: 39
    Last Post: 08-22-2013, 09:44 PM
