Likes Likes:  10
Thanks Thanks:  8
Results 1 to 14 of 14
Thread: Tire Pressure Question
    5+ Posts Rob Johnson's Avatar
    Sep 2022
    WYOMING, MICHIGAN
    Default Tire Pressure Question
    so "New to Trikes" as in conversion was done a month ago... My Dealer recommended right side tire be 35 but left side tire be 25 ... Road Crown was the reason given.... I'm a bit leery of this and have so far been most comfortable at 24 right side and 18 left side... anyone else every deal with this or should I run them both the same ... thx in advance..
    Hi Robert, to Trike Talk and your first post
    I would suggest 22-24 PSI in both rear tires, try that , it should ride smooth and track just fine
    If you scroll down you will see similar threads to see what others are doing
    Sep 2022
    WYOMING, MICHIGAN
    Thank You for the quick response. I will try that tonight..
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Welcome Robert. Your rear tires should be the same pressures for both. You didn't indicate what trike model you have but assuming it is a newer Goldwing and running a traditional motorcycle front tire, that should be kept at 41-42 PSI. Your rears should be 22-25 PSI. I keep mine at 23. Having different pressures in the rear only makes sense if you are going straight on a constantly angled, crowned road and never go around any corners. Good luck..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    Quote Originally Posted by Rob Johnson View Post
    Rob….Run both the rear tires with the same PSI….And if you have to talk tires and PSI with that dealer again..”Don’t!”…
    Sep 2022
    WYOMING, MICHIGAN
    Quote Originally Posted by cScjhb View Post
    ya know that's how I felt as well but didn't want to argue with the professionals'.... Its a VTX1800T with a Motor Trike Conversion... Had the bike since new bur have aged a bit since I bought it and decided this year to convert... Wife and I are enjoying it so far.
    400+ Posts
    Feb 2020
    Washington Pa USA
    Welcome from SW PA Robert in PA used a lot of road crown and with my trike I ran 22 in both rear with no problem
    250+ Posts
    Jan 2012
    oz
    Your dealer is a idiot. Always run the same pressure in the rear tires 22-26 is the norm
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Both rear tires should be the same pressure.
    We run 22-24.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    Take a look at this screenshoy if a manual. I know it's for a different brand (Lehman Master Manual) but it has a very good explanation on the rear trike tires. Hopefully you can enlarge it and be able to read it.
    As far as mine, I usually run the rear tires at about 22psi and front around 36-38psi. I have found that running 41-42psi on front tire makes the ride a bit rough as the roads I commonly drive on are not the greatest. On trips where the roads are better, I have bumped it up but locally I keep it below 40.
    Sep 2022
    WYOMING, MICHIGAN
    So I set both tires to 20 psi and the ride is better as well as the handling, may mess with it further as time goes by.... left front tire at 42 .... Its a VTX1800T with a Motor Trike Conversion.... Has 5 way adjustable shocks and air bags as well .... Looking forward to taking it on a color tour in northern Michigan this year...
    Sep 2016
    Springfield, Mass. USA
    I also run 22# in each REAR tire............
    9/16/22
    Sep 2016
    When I had my trike built, I have to say that my builder also told me to run two different pressures in the rear tires also....(that surprised me too) BUT now I just put in 22#'s in each tire.................
    9/19/22
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    I run 24 in the rear and 38 in the front and the only Crown I worry about is in a purple bag
    2019 Goldwing CSC
  1. Tire Pressure for MPA Front Tire
    By cScjhb in forum Honda Trikes
    Last Post: 09-13-2020, 12:11 PM
  2. TPSM ?? or tire pressure system question
    By JaysGone in forum Honda Trikes
    Last Post: 01-28-2015, 07:18 AM
  3. tire pressure???? suspension pressure???
    By flangar in forum Stallion Trikes
    Last Post: 05-10-2014, 09:53 PM
  4. tire pressure on goldwings/trikes question
    By bumlbe in forum Honda Trikes
    Last Post: 02-03-2011, 10:20 AM
  5. tire pressure question-please
    By grampadonut in forum Tires, Wheels, Brakes, Front End
    Last Post: 07-21-2010, 07:24 PM
