14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  2
Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Steering damper mounting bolt torque?
    50+ Posts
    Aug 2022
    Independence, mo usa
    Default Steering damper mounting bolt torque?
    The steering damper bracket bolt is so loose I can turn it with my fingers anyone know the torque of that bolt? Its so loose I need to tighten it before the next ride. Its (K) on the drawing. Thanks, Richard
    22 Freewheeler
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Not sure which one you need to tighten, but the Trike Service manual Supplement lists these specs.
    Steering damper acorn (16–20 ft-lbs
    Steering damper bracket to frame screw:FLRT (22–28 ft-lbs)
    Steering damper locknut (16–20 ft-lbs)
    Steering damper side bracket acorn nuts: FLHTCUTG (120–180 in-lbs)
    These also retain the auxiliary/fog/HDI headlamp brackets.
    Steering damper side bracket to fork bracket screws: FLRT (20–25 ft-lbs)
    50+ Posts
    Aug 2022
    I tightened it up 25 Ft pounds. Thanks for the reply JTJersey. I appreciate it.
    22 Freewheeler
  1. Replies: 9
    Last Post: 06-17-2021, 07:51 AM
  2. Bolt Torque Chart
    By Jack Klarich in forum General Harley Chat
    Last Post: 12-13-2018, 05:16 PM
  3. Harley 4 bolt to GM 5 bolt adapter
    By TK8614 in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-08-2016, 08:35 PM
  4. To Damper or not to Damper
    By americanbadass in forum Accessories
    Last Post: 06-10-2013, 11:07 AM
  5. Tri-Glide Steering Damper
    By Tonyd in forum Harley Tri Glide
    Last Post: 03-15-2010, 12:47 PM
