Results 1 to 1 of 1
Thread: 1999SE MotorTrike fork oil capacity
    Jun 2022
    Branson, Mo
    Default 1999SE MotorTrike fork oil capacity
    I’m rebuilding front forks. I’ve disassemble and cleaned the tubes and replaced all bushings and seals. I * did not * mess with the anti dive valve. All the info I find says for the right fork capacity is 12.7oz/ 7.6” of head space between fluid level and top of the piston-empty and collapsed. I verify with several different measuring devices, re-verified my liquid amount and come up with only ~6.6” of free space head space with 12.6oz of fluid. 2 questions: will the ant dive valve retain some liquid upon a complete shock rebuild and what’s more important, head space or liquid amount? ( I’m running Progressive springs).
    - By the way I calculate approx 3/4oz needs to be removed.
    Larry
  1. Screamin Eagle High Capacity Oil Pan
    By geezerglide11441 in forum Harley Tri Glide
    Last Post: 10-16-2014, 05:14 PM
  2. Trans oil capacity
    By Lakeman in forum Harley Trike Conversions
    Last Post: 09-07-2013, 12:05 PM
  3. Gas tank fuel capacity
    By haawg in forum BMW Trikes
    Last Post: 05-21-2013, 09:21 PM
  4. 1999SE Lehman Trike Done
    By asigetic in forum Honda Trikes
    Last Post: 07-24-2012, 05:48 PM
  5. Colt Trailer Capacity
    By Switchback in forum Stallion Trikes
    Last Post: 09-17-2010, 03:00 PM
