Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  10
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: Freewheeler maiden voyage check engine light
    10+ Posts Maxwell's Avatar
    Sep 2022
    Crescent City
    Default Freewheeler maiden voyage check engine light
    Brand new Freewheeler. Dealer delivered it to my house a week or so ago. Went to go take it out today for the first time and the check engine light stayed on. Checked for codes. There was a P1608h code which is a loss of continuous battery. I had it on a battery tender which I disconnected before riding (duh). I did pull the main fuse a few days ago to install a rear rack with brake light. What should I do at this point? How do I get the check engine light solved?
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Hi Max, Write the code down, then see this thread on how to clear it. After that you may want to have your dealer take a look at it
    https://www.triketalk.com/forum/thre...-trouble-codes
    It could be as simple as when you pulled the main fuse, the ECM saw an interruption of power, or the battery cables may not be tight @ the battery, sometimes the factory errors during assembly
    Sep 2022
    Crescent City
    Thanks Jack. I wasn't expecting the check engine light to be related to such a simple code, but I guess things have changed. I cleared the code, and the check engine light went out. Took it for a 20 or so mile ride and everything was fine. My nearest dealer is a couple hours away so I don't show up there very often. Thank you for your help, sir.
    50+ Posts
    Aug 2022
    Independence, mo usa
    Max my 2022 Keeps setting codes. I clear them and after a couple of riding it then power off the power on cycles more codes pop up. I'm keeping a list of the codes it sets. I spoke with the dealer and they said the 22's are more prone to throw codes if not left on a tender all the time. I think that is BS but what do I know.
    All the codes clear ok and the trike runs ok. For how long, time will tell. I'll keep riding it till it quits then worry about it.
    22 Freewheeler
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    My 21 TG showed a check engine light and turned out to be a loose neg battery cable.
  6. #6
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Quote Originally Posted by Kneesinbreeze View Post
    Max my 2022 Keeps setting I spoke with the dealer and they said the 22's are more prone to throw codes if not left on a tender all the time. I think that is BS but what do I know.
    Ask those retards if they will supply extension cords so your covered wherever you go. Do car dealers tell you this. Id bring the trike back and tell them I want my money refunded. Where do they find these people?
  7. #7
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Olddog View Post
    Most every electrical issues start @ the battery albeit trouble codes and or the health of the battery and connections
  8. #8
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    This is complete nonsense/ a non answer from any dealer IMO
    HD needs to get these electrical issues fixed now, it makes them look weak with answers like this from dealers
  9. #9
    50+ Posts joebedford's Avatar
    Jun 2022
    Jasper, Ontario, Canada
    DW's 2022 Freewheeler has NEVER been on a tender and has not thrown a code (yet).
    AND my 20 year old FLHTCUI has never been on a tender. It threw a code a few years ago when the regulator died.
  10. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    My 21 Freewheeler lives on a tender, never thrown any codes
  11. #11
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Quote Originally Posted by Maxwell View Post
    Jack has saved me from making a couple of trips to the dealer.
    My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
  12. #12
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    My neighbors 2020 Tri Glide will throw a code if he doesn't keep it on a tender if he doesn't ride it for a couple weeks. As long as you ride it every couple days there should be no reason for a tender.
  1. Maiden Voyage
    By Guitarman in forum VW Powered Trikes
    Last Post: 05-14-2016, 01:44 PM
  2. New Ride Maiden Voyage
    By Phill Griggs in forum Trike Travel
    Last Post: 05-04-2013, 08:28 PM
  3. My Maiden Voyage
    By Southpaw in forum General Discussion
    Last Post: 10-04-2012, 10:29 PM
  4. Maiden Voyage Today!
    By wingking51 in forum General Discussion
    Last Post: 04-02-2010, 03:47 PM
