SSpoon9Marc HNew Member Introduct...Hello from VA
SSpoon9ZammyNew Member Introduct...Hello from VA
SSpoon9Uncle FesterNew Member Introduct...Hello from VA
SSpoon9rhino 2New Member Introduct...Hello from VA
SSpoon9trike ladyNew Member Introduct...Hello from VA
SSpoon9SullyNew Member Introduct...Hello from VA
SSpoon9Jack KlarichNew Member Introduct...Hello from VA
SSpoon9GorillaNew Member Introduct...Hello from VA
SSpoon9SSpoonNew Member Introduct...Hello from VA
Likes Likes:  6
Results 1 to 13 of 13
Thread: Hand controls?
    1+ Posts
    Oct 2022
    KENOVA
    Default Hand controls?
    So saying I am a newbie isn't even close to the reality!
    Okay guys, girls... whatever. lol...
    I haven't ridden a motorcycle in 25 years. I have wanted a VW trike since I was 14, I'm 48.
    I bought one. LOL... Yeah, i know... I am all 7th grade giddy inside...
    SO... Buying something without thinking it through! lol...
    I have bad legs... How hard would it be to get a shop to but hand controls for breaks clutch and throttle? I am getting a lot of work done on it. Paint job, etc... I haven't even gotten in my hands yet. These are all just posing questions I have. Sure, i could ask whomever I take it to, lol... But I was hoping you guys could point me into direction of quality and working!Name:  Vw trike.jpg
    Thanks for any response guys.
    K.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by kane100574 View Post
    K.
    Tim......... Welcome To Trike-Talk...........
    2019 Tri-Glide.......
    1+ Posts
    Oct 2022
    KENOVA
    Thanks, man!
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Welcome to Trike Talk!!!
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Welcome
    Welcome! Where the hell is Kenova?
    JakeJacobsen@Pinterest.com
  6. #6
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    I cannot help you, but I can offer a big TEXAS
    My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
  7. #7
    1+ Posts
    Oct 2022
    KENOVA
    Thanks guys! Kenova is in west Virginia! lol, I said that too the first time i heard it.
  8. #8
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    to Trike Talk
    Have you tried Google search for disabled trike controls?
  9. #9
    150+ Posts
    Jan 2011
    Osceola Mills,PA,USA
    You would probably need some kind of boosters to help with the brakes and clutch. Also drop down the page to the Enabled Trikers thread, you might pick up good ideas there.
    Welcome
  10. #10
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    You will need some power adders. It is really difficult to generate enough power with the grip of your hand to work automotive size systems.
    Servos and/or brake boosters. Even something newer.....a lot of newer cars have a brake booster servo that is not vacuum..... electric instead.
    It will take fairly heavy custom modifications/fabrication/engineering to get it all to work out.
    Like said above.....find out what others have done.
  11. #11
    1+ Posts
    Oct 2022
    KENOVA
    to Trike Talk
    LOL, yeah, you would think I would do that!! my brain is scattered the last 8 weeks
  12. #12
    May 2016
    Hemet, Ca. USA
    Default Hyd controls
    Tim/Rex, With the rear being VW how about Hyd. levers on the handlebars and VW clutch slave(s) for the clutch and brakes? Or is this idea too much over the top?
  13. #13
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    The VW rear brakes and the hydraulic clutch require a master with a larger displacement than the typical motorcycle master can provide.
    There are a few oddball/unusually large piston size motorcycle masters out there. I have seen it done.
    A very light (low clamping force) pressure plate.
    And it has to be a pressure plate that does not need much stroke.,...ie a diaphragm type.
    Then use the long type throw out lever like what is used on race cars with stuff clutch.
    The dune buggy slave.
    And then the oddball large piston motorcycle master.
    Do some big hand exercises to build up some monster grip strength.
    And then you can have a direct hydraulic handlebar clutch.
    I have yet to see someone get a usable handlebar on the VW brakes. Sorta the same thing as the clutch set up but once you get there on displacement it then takes more force than you can put out on the lever.
    Your best bet would be to remote actuate a powered master for each.
    It is do-able.....it will just take more than you think it would.
  1. Light up hand controls
    By consitter in forum Harley Trike Conversions
    Last Post: 02-28-2016, 01:19 PM
  2. gummy controls.
    By IN Skuter Dude in forum Honda Trikes
    Last Post: 01-13-2012, 01:01 AM
  3. Forward Controls?
    By classicfins in forum VW Powered Trikes
    Last Post: 03-06-2011, 10:44 AM
  4. A/C controls
    By Trikerjim in forum General Discussion
    Last Post: 07-23-2008, 04:10 PM
