Likes Likes:  4
Thanks Thanks:  1
Results 1 to 5 of 5
Thread: Mr Jack TSSM Help Please
    20+ Posts
    Mar 2022
    LHC, AZ, US
    Default Mr Jack TSSM Help Please
    Mr. Jack,
    Been riding many years, but moved to trike in Apr. It's a 2012 w 16k. Just this last week the right blinker started hyper flashing on front only. It gave a B1122. I cleared the code and it has not reappeared. I visually inspected bulbs, sockets of all 4 and they all look good. Still need to run a voltmeter.
    Is there a procedure for testing the TSSM if it all checks out? Thank you.
    -Many Blessings,
    JMan
    Not that I know of but there is a reset for it, see here
    • Move kill switch to off position, turn ignition on-off-on-off-on.
    • Press left turn signal switch twice, pause, and lights will flash.
    • Press right turn signal switch once, pause, and lights will flash.
    • Press right turn signal switch once, pause, and lights will flash twice.
    • Press right turn signal switch once, pause, and lights will flash three times.
    • Press left turn signal switch once, and light will flash a number of times to indicate an error code.
    • There is 1.5 seconds between flashes to indicate 1st and 2nd digit of codes and four second pause between codes.
    • Press and hold left switch down for five seconds, and light will flash twice to indicate the TSSM is reset.
    • Turn ignition to off.
    20+ Posts
    Mar 2022
    LHC, AZ, US
    Default Thank You
    Thank you. I'll give this a try too.
    I've been on many different HD forums over the years, and this one by far is the most laid back, friendly, and actually informative.
    Thumbs up
    Quote Originally Posted by 19jman View Post
    I agree
    Have you replaced any lighting on your trike recently?
    Hyper flashing can be traced back to bad grounds, poor connections in light sockets and voltage drops also along with combos of led bulbs
  1. Please please help, or I’m a dead man!
    By AR198 in forum Harley Freewheeler / Road Glide 3
    Last Post: 07-23-2019, 02:41 PM
  2. Jack I need help. Got a code?
    By grandpawj in forum Harley Trike Conversions
    Last Post: 07-16-2017, 10:37 PM
  3. Need help finding a small trailer front jack for my motorcycle trailer
    By Urlawyer in forum Harley Trike Conversions
    Last Post: 07-23-2014, 07:53 PM
  4. Help me get started! (please)
    By Big_Steve in forum General Discussion
    Last Post: 07-08-2010, 12:44 PM
  5. Please Help! New Trike Question
    By Chil in forum General Discussion
    Last Post: 07-07-2008, 06:42 PM
