Likes Likes:  14
Thanks Thanks:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
Thread: HEIM / Spherical Rod Ends PTFE NYLON Isolated Greaseable
  1. #21
    250+ Posts
    Jan 2012
    oz
    PLEASE end this thread. Been going on forever. The wind was knocked out of it a while back
  2. #22
    350+ Posts 3W-lonerider's Avatar
    Feb 2008
    Shippensburg, Pa
    Quote Originally Posted by ontheroad View Post
    I have a gl1800 with a motor trike conversion. My rear end is lower on the right side by close to an inch. I have checked my cross bars and they are both easily movable with thumb and finger. I understand I need to disconnect the ladder bar on the lower joint on the low side and unscrew it a couple of turns. Will that be enough to raise my 1 inch or so. I just installed the larger air bags and have been very pleased with them. What should I run my shocks on . Now I have them backed off all the way. I am thinking two clicks. Thanks for the info....Oh I do have a solid axle.
    yes you will need to adjust the lower heim on the low side i would go 3 turns then check the height. then your going to have to re-adjust the cross bars because that will change to. also keep in mind, do not go by a measurement from the body to the floor as to whether or not it is level. a more accurate way to tell is the front tire. measure from center of the tire to the edge of the contact wear. it should be even.
    as far as your shocks. set them on the lowest setting and put alittle more air in the bags. it will ride much better.
    reason i say don't go by the body. is because if you look under the rear you will see washers between the body and the frame. a body can be shimmed to make it look level or uneven.
  3. #23
    10+ Posts
    Jun 2022
    COOPER, tx, USA
    Quote Originally Posted by 3W-lonerider View Post
    Thanks Lonerider for the good info. I will get on the adjustment. I am thinking I will run from 15 to 20 lbs in the new air bags. And leave the shocks on the lowest setting. This is my second trike, both being Motortrike solid axle
    . Would kinda like a Roadsmith because they a bit longer
  1. Video - Heim Joints Don't Stranded if/when the Factory Shift Rod Ends Fail
    By DK Custom Products in forum DK Custom Products
    Last Post: 08-27-2021, 01:37 PM
  2. Rod Ends
    By rocket1lf in forum Stallion Trikes
    Last Post: 06-17-2016, 10:59 PM
  3. Not the ladder bar , but the heim joint broke
    By Captain H in forum Stallion Trikes
    Last Post: 12-02-2015, 08:40 AM
  4. Squeaky Heim joints
    By Wayne Harmsen in forum Motor Trike
    Last Post: 02-02-2011, 06:02 AM
  5. ripped heim joints out of ladder bar?????
    By Histicku in forum Honda Trikes
    Last Post: 12-03-2010, 12:45 PM
