Likes Likes:  18
Thanks Thanks:  7
Results 1 to 16 of 16
Thread: New Tri Glide Owner
    5+ Posts
    Sep 2022
    New Orleans, LA, USA
    Default New Tri Glide Owner
    I’m the owner of a new Tri Glide Ultra Classic. I’ve only had it one month, drove 300 miles, and it’s already in the shop. I haven’t noticed anything wrong except the TC & ABS trouble lights came on. I took it to the dealer 6 days ago and still waiting for a diagnosis. I’m curious if anyone else has experienced anything similar.
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    Tom,you should learn how to read the codes. Most of the time you can clear the codes showing and they will not come back. If they do return,then make the trip to the dealer.
    2021 Tri Glide in Billiard Red
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    About two months into owning my brand new '21 Freewheeler a "Lost com to ABS" error code popped up. I cleared it and have never seen it since. When I mentioned it to the dealer at my service they billed me a $100 shop time to tell me no codes were present. I won't make that mistake again.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Tom66 View Post
    Tom, look here on how to look up trouble codes on your trike, scroll down to the bottom to see how to retrieve the codes
    https://www.wilkinsharley.com/--Chec...rley-Davidsons
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by JTJersey View Post
    You have a 2 year warranty, I would be complaining to the owner over this
  6. DKCustoms postbit
  7. #6
    80+ Posts
    Aug 2016
    sebastian FL
    Agree with Jack, I would be telling them to pound sand for the hundred
  8. #7
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    About a year ago, while on a lunch ride, my 2020 did that. I cleared the codes, rode home and forgot about it until just now.
    Jack's info on the codes has saved me 3 times that I can recall, but there may have been others. HD isn't getting $100 to tell me about codes past or present.
    My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
  9. #8
    5+ Posts
    Sep 2022
    Default Re: New Tri Glide Ultra
    Thank you all for the replies. I actually figured out how to pull the codes before I took the trike in. It only pointed to a brake sensor issue. While researching I learned about the 2019 recall and I didn’t want to take any chances so I took it to the dealer out of caution. I didn’t expect them to look at while I waited, but after 2 days, several unanswered phone calls then me telling them I’m coming to get my trike is when they finally looked at it. They only told me what I had already learned from the codes I pulled. That was 4 days ago and I still don’t know what the problem is. If they don’t know by Monday afternoon, I’m taking it out of there. With it only being 30 days old and 300 miles, it has to be a warranty issue so if they charge me for anything I’ll be calling Milwaukee while I’m there.
  10. #9
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Stand your ground, your trike should have already had the recall done, dont take this crap from your dealer, ask them if the recall has been done, if not they need to make it right
    read more here
    https://oemdtc.com/3146/m1506-recall...action-control
  11. #10
    5+ Posts
    Sep 2022
    I asked about the 2019 recall and they said there weren’t any issues with the 2022 models when it comes to that recall.
  12. #11
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    I have a 21 Freewheeler and all is good with it
    There are some bad stories out there where some had real serious problems with ABS brake lock up on 19 and early 20 models
    HD has finally got the new ECM worked out, no more bad JUJU for now
  13. #12
    5+ Posts
    Sep 2022
    Unhappy Bad ABS brake module
    So I finally got the diagnosis from the dealer. I have a bad ABS brake module. I would never expect that to happen on a brand new bike after just 1 month and 300 miles.
  14. #13
    5+ Posts
    Sep 2022
    Default Update: Bad ABS brake module
    The dealer called. They expect the part in 2 days. I’m satisfied with that. I think the phone call to HD HQ Customer Care helped.
  15. #14
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Tom - did you get your bike back? There may be a recall for the brake sensor. When you were riding, was your cruise control working?
  16. #15
    5+ Posts
    Sep 2022
    Default Cruise Control not working properly
    Quote Originally Posted by cycle7447 View Post
    It’s funny you asked that. Yes, I got my bike back. They replaced the brake module. The ABS/TC worked for about 300 miles then I noticed the TC and ABS lights come on again. I pulled over, turned everything off, and the lights stayed off for about 100 more miles then it happened again and the dummy lights went off. Coincidentally, I noticed my cruise control acting up. As I was cruising around 60 mph, it suddenly cut off and I couldn’t get it to set again. After about 10 miles it was working again. I took it in for the 1,000mi service and explained everything going on. They found no issues with either the ABS/TC/module or the cruise control. This was only a couple days after the brake light recall notice went out and they said they didn’t have the proper equipment yet to correct the recall. But since I’ve had it back I’ve driven about 150 miles and the cruise control is not working properly. I’m thinking it’s related to the recall.
  17. DKCustoms postbit
  18. #16
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    If the brake sensor is communicating to the Computer/ECM saying that your brake lights are “On” your cruise control will not work and that has something to do with the recall..
    2019 Tri-Glide.......
  1. New Member / New Owner Tri Glide Ultra
    By Tom66 in forum New Member Introductions
    Last Post: 10-16-2022, 09:02 PM
  2. New Trike Owner NE Ohio with a 2012 Harley Tri Glide
    By milemaker in forum New Member Introductions
    Last Post: 02-12-2016, 08:23 PM
  3. New Tri Glide Owner with a burning question
    By daf62757 in forum Harley Tri Glide
    Last Post: 12-24-2015, 11:50 AM
  4. New Tri Glide Owner
    By Bagman1 in forum New Member Introductions
    Last Post: 11-11-2015, 12:30 PM
  5. New Member, New Tri Glide Owner.
    By Big Kahuna in forum Harley Tri Glide
    Last Post: 09-02-2013, 09:09 PM
