Likes Likes:  2
Thanks Thanks:  3
Results 1 to 8 of 8
Thread: Code P2135h
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Default Code P2135h
    My '21 Freewheelers check engine light came on today on my way to lunch. Turned around ( ) and found code P2 135h. Something to do with my throttle sensor. Did NOT clear the code. Restarted the trike and went to lunch. No check engine light reappeared. After I got back home I went in to clear that code, but it indicated there were no codes. Was this a phantom code that disappeared miraculously?
    Possible, have you recently washed your trike or rode in heavy rain?
    If the code comes back, unplug and clean the wire connector pins @ the throttle actuator
    The code can be an interruption of voltage at that connection
    Of note the H at the end is a Historic code
    They can after 40 start cycles clear themselves
    It also means that the code was setting prior, the ECM saw something it did not like over a period of time
    That code was lurking in the background for a time, the voltage signal was out of parameters, but is no longer
    If it comes back on a deeper dive into diagnostics will be needed, for now I would for sure unplug the connector, clean the pins on both the male and female pins and apply a little dielectric grease and ride it
    I had that code on my 15 Freewheeler coming back to FL from Mn
    I was riding on the tail of a tropical storm on I 75, the rain was torrential
    At 1 time the engine sputtered right before the CEL light came on
    When I stopped in Lake City Fl I knew right away what the problem was
    I always carry some cleaner and dilectric grease, so I did the clean and relube
    Never skipped a beat after
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Possible, have you recently washed your trike or rode in heavy rain? If the code comes back, unplug and clean the wire connector pins @ the throttle actuator The code can be an interruption of voltage at that connection
    Closest she's ever been to being in the rain was road spray and light drizzle coming back from FL. Hmmm, can I blame you?
    I saw by your second reply that the H means it's an Historic code. I've never experienced any riding problems such as you described so I have no idea why it would have reported that, but then I did get a check engine light before my 10,000 miles service that indicated a Lost Comm with ABS. Cleared that and it's never come back. The service dept checked for it, but found nothing wrong and charge me $120 labor because it wasn't a warranty issue. I think I'll just keep an eye on it for a while. Thanks for the tip.
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Are these the connectors your referring to?
    Quote Originally Posted by JTJersey View Post
    No, the ones @ the Throttle body there should be a plug in, similar to this
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Oh, this guy. #14.
    Oh, this guy. #14.
    Look at the picture you posted, see the 3 screws @ the left, look below to the right, that is where the wires would plug in
    No, that is the intake temp sensor
    The throttle plate sensor ( that receives the input from the TBW from the twist grip) should be either on the bottom of the induction module or the side of it
  1. PPG Paint Code
    By onahog in forum Harley Trike Conversions
    Last Post: 03-28-2013, 11:12 PM
  2. Wiring Color Code
    By Blueribbon in forum Honda Trikes
    Last Post: 11-02-2012, 08:19 AM
  3. Paint Code For 2010 Triglide
    By rgc in forum Harley Tri Glide
    Last Post: 03-12-2012, 08:48 PM
  4. 11' Tri Glide ECM Update Code Number
    By Trent in forum Harley Tri Glide
    Last Post: 11-18-2011, 09:43 PM
  5. About that new ECM code download to stock Tri-Glide
    By wonderment in forum Harley Tri Glide
    Last Post: 10-28-2011, 01:39 AM
