Likes Likes:  24
Thanks Thanks:  16
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 54 of 54
Thread: 200,000 HD Touring Bikes Recall Issue Including Trikes
  1. #41
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Dealer just called - my bike is ready. They did the reflash based on the bulletin and the cruise started to work again.
    When they did the reflash, it took my bike back to a two-wheeler. I was wondering about the TPMS - not shows the front wheel and one rear wheel. Main thing is I don't have any warning lights about the low pressure.
    He asked if he should try to redo it - and take it back to the three-wheeler. I am just a little concerned - first because everything is working and second, I may need the new brake sensor from Harley and that will not be in until after Christmas.
    So, I am going to opt and just let it stay as is. The initial reason for having this done was to get rid of the warning lights from the low (missing) air pressure. This seems to resolve that.
    I am headed out for the holidays - bike will be delivered to me when I return. Hey, I am happy with that.
  2. #42
    1000+ Posts
    Aug 2012
    Pendleton, Oregon USA
    Default Recall
    Received the notice from the MOCO on the Wife’s CVO yesterday, its 27 deg.here this morn. with a high of 34…….. think we’ll wait awhile to make that appointment at the stealer, LOL!
    Hope everone has a GREAT THANKSGIVING!
  3. #43
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by Peter A. View Post
    Might as well ..Parts not available till after late Dec. as of now.
  4. #44
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Has anybody had this brake light issue happen to them, or know of anybody it's happened to? Just curious as to how wide spread this deal is. Can't find out much about it.
  5. #45
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Quote Originally Posted by JTJersey View Post
    Nope. Put my VIN into the website for the recall, and they said nope. Late 21 TG.
  7. #46
    I am reading this recall as a potential problem that HD is trying to get out front on
    I am not worried a bit over this yet, I figure if my cruise stops working, I know how to scan the codes and know how to read the diagnostic flow charts
    I think HD has had ongoing problems with the anti lock brakes and traction control on trike models for at least 2 years albeit they did thru BCM re flashes fix many of the early systems
    One other thing you brought a few posts ago, the switch they are replacing
    This is the only switch I find that probably is the rear brake switch, other than the hand switch operated by the handle bar lever
  8. #47
    May 2020
    Palm Coast, FL, USA
    Had the switch replacement done 2 yrs ago. The exhaust heat cooks them as it’s next to the cat on my 2012. No more cat no more issues.
    Just an FYI: The Switch/Pressure Sensor is not located where yours was. The 2019 & Later that have the TCS System have the Sensor located on the ABS Module under the R/H Side Cover.
  9. #48
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    My neighbors 2020 had a brake light issue this past July. We were in Maggie Valley and his brake lights stuck on and his cruise didn't work. After we got home he pulled the brake light switch that sits on top of his ABS module and as soon as he released it a big puff of air came out, so after about two minutes some fluid started to drip out. So he screwed it back in, and the lights and cruise have worked ever since with no codes. He did get his notice for recall also.
  10. #49
    80+ Posts Jd1a's Avatar
    Oct 2018
    Waddell, AZ USA
    My letter arrived yesterday, will talk to the dealer about the fix.
  11. #50
    550+ Posts
    520fd's Avatar
    Aug 2010
    Davenport, Iowa USA
    Ya, I got my recall noticed from the Mothership about 2 or 3 weeks ago. I talked to a fellow triker at the HOG Christmas party last night. He said he talked to a Harley tech the other day. The Tech said there was a harness involved in the repair also. I've never heard of this.??????
    2022 Tri-Glide Black.
  12. #51
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Quote Originally Posted by 520fd View Post
    Sir - take a look at the very last paragraph on page one of your letter. They mention "a new brake switch". This is the harness in which he is referring.
    Parts are supposed to be in near Christmas
  13. #52
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Picked up the trike from my 5K service, this was on the invoice:
    Trike had open recall 0635
    Installed 91500112 :Kit, Recall 0635 Signal, Brake L Qty:1
    Claim Type SRC - Part # 41000341F
    Labor Code 2818 - Time 1.8
  14. #53
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Coming up on a 20K service on my '21 Freewheeler and I'm sure they're going to do the recall as part of it. I understand they have to flash the ECM and I always get nervous about them doing that. The Free is running great and I don't want them screwing it up. Has anyone heard of any downsides to having this done? The trike isn't exhibiting any brake light issues, but I guess it's not going to matter once it's in their hands.
  15. #54
    JT, I could be wrong but I think the BCM controls the brake module, that said even if they have to update the ECM, there are partitions in there and the Digital Tech Scanner they use can scroll thru the place they need to update without affecting any other areas of the ECM or BCM
  1. New to the forum and new to touring bikes and trikes in general
    By mdd07 in forum New Member Introductions
    Last Post: 09-12-2020, 08:05 PM
  2. HD Clutch Recall 2018...Over 200,000 Affected!
    Last Post: 01-09-2019, 12:04 PM
  3. Replies: 2
    Last Post: 05-14-2015, 10:33 PM
  4. ****Special on All Foot Pegs - Including New Tight-n-Low Trap Moto Pegs****
    By DK Custom Products in forum DK Custom Products
    Last Post: 01-20-2015, 05:40 PM
  5. 200,000 dollar trike w/ accesaries
    By meredog in forum General Discussion
    Last Post: 03-02-2013, 01:44 PM
