Bonsai5ol' schoolNew Member Introduct...New member from Texas
Sunman5rhino 2Honda TrikesF1 Warning Light
Papa Zook1Papa ZookHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
Bonsai5rhino 2New Member Introduct...New member from Texas
Bonsai5GorillaNew Member Introduct...New member from Texas
Rawhideken1714TGHarley Tri Glide2024 Tri glide
kj5ix32trike ladyHonda TrikesMotor Trike Service Manual Finished
Bonsai5trike ladyNew Member Introduct...New member from Texas
Bonsai5BonsaiNew Member Introduct...New member from Texas
Sunman5BowdenTrikeHonda TrikesF1 Warning Light
LD-Ordie10Marc HNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie10ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie10ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie10trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie10SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie10Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17LD-OrdieHarley Tri Glide2024 Tri glide
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie10LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
kj5ix32ADSavareseHonda TrikesMotor Trike Service Manual Finished
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Gorilla2Jack KlarichEnabled TrikersFull length floorboards
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  2
Results 1 to 4 of 4
Thread: HD Factory Battery Tender Lead
    20+ Posts TrailtrekerNJ's Avatar
    Jun 2017
    Dingmans Ferry, PA USA
    Default HD Factory Battery Tender Lead
    Purchased a new Battery Tender for FW, plugged in, no good.
    Tested HD factory installed lead, coming back dead on back feed.
    Installed Battery Tender jumper leads directly to battery, tested alive on back feed, connected tender, working.
    Tried following HD lead but cannot find where it goes or an in-line fuse.
    Found an old post where it was determined that the "PA 20amp fuse" was defective.
    Is this fuse the culprit?
    Does it power anything else important, before I pull it out?
    P.S.
    The battery post screws are horrible.
    So small and do not seem to leave to much room to add accessory leads.
    What year?
    If it is a factory wired tender the P&A fuse is the fuse you should look at
    Jun 2017
    Name:  fuse panel.jpg
    Thanks Jack
    I Looked into the fuse panel and this is what I have:
    1 - Radio Power (20a), empty
    5 - Cooling (10a), empty
    8 - Cooling Relay, empty
    4 - P&A (20a), found a 15a fuse, BLOWN.
    Replaced, like & kind for now, Battery Tender working.
    Will replace with 20a, when I get to an auto parts store.
    Does "P&A" = parts and accessories?
    Can those empty fuse holders somehow be used to add/protect accessories?
    Quote Originally Posted by TrailtrekerNJ View Post
    Thanks Jack
    Yes it does, good job
  1. factory battery tender
    By grunt67 in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-18-2020, 11:36 AM
  2. What model Battery Tender are most using?
    By azbob09 in forum Harley Trike Conversions
    Last Post: 12-20-2012, 09:27 PM
  3. Battery Tender Attachment
    By AZTriGlide in forum Harley Trike Conversions
    Last Post: 10-08-2012, 11:34 AM
  4. battery tender
    By Teal in forum General Discussion
    Last Post: 02-09-2012, 01:04 PM
  5. Battery Tender
    By rgc in forum Harley Trike Conversions
    Last Post: 11-13-2011, 07:08 PM
