Likes Likes:  1
Thanks Thanks:  1
Results 1 to 11 of 11
Thread: Grease fitting on a 2001 Gl1800 trike Roadsmith
    Nov 2022
    Metchen NJ USA
    Question Grease fitting on a 2001 Gl1800 trike Roadsmith
    Hi
    Just got my GL1800 Roadsmith trike couple months ago. Trying to do some maintenance on it cuz it seems like it wasn't done in a long time.
    Read in another thread that you are grease fittings on the drive shaft. Just wondering is there any other PLACES that needs to be greased??
    And what type of Grease most people are using??
    Have ridden for many years (two-wheelers), but this 3-wheeler there is a big difference, not only riding but maintenance too.
    Thanks in advance I do appreciate the help
  2. Roadsmith banner
  3. #2
    Quote Originally Posted by Mactell View Post
    Hi
    Just got my GL1800 Roadmaster a couple months ago. Trying to do some maintenance on it cuz it seems like it wasn't done in a long time.
    Adee.......Welcome To Trike-Talk............
  4. #3
    Sep 2016
    Springfield, Mass. USA
    The only two grease fitting jerk's r on the drive shaft that I know of... I jack up rear of bike and rotate tires till you see the jerks, and shoot some molly grease into them until you see grease spitting out the edges...(takes only one/two pumps of the G. gun) ***Don't overfill***
    11/14/22
  5. #4
    Nov 2022
    Metchen NJ USA
    Thanks appreciate the help
  6. #5
    If and when you change joints check out this
    250+ Posts
    Jan 2012
    oz
    Doug at Roadsmith- Co-owner Told me the driveshaft does not need grease added to it.
    Sep 2016
    Jack I didn't know about that grease jerk, can that be lubed w/o take'n it apart?
    11/21/22
    11/21/22
    Yes indeed, have been using them for years on autos and trucks, no hassles and much easier
  10. Roadsmith banner
  11. #9
    Sep 2016
    The good folks at Roadsmith trike told me that's the only thing to worry about, under the trike kit body to lube..
    11/24/22
  12. #10
    Nov 2022
    Metchen NJ USA
    Default Grease fitting on Roadmaster trike
    Just talked to Road Smith, to get more information about my bike, the kit was put on in 2008.
    So I asked him about the grease fittings.
    He said I just need to grease the 2 fitting on the shaft near the back of the engine.
    I also have one in the middle of the shaft and he said don't worry about it, It doesn't need to be greased.
  13. #11
    Sep 2016
    Thank you for this information: I was also with the same thoughts, BUT if I'm miss'n grease shots locations , I want to know about them
    12/11/22
  1. U-Joint Grease Fitting(s) Location
    By Ruothere in forum Honda Trikes
    Last Post: 06-25-2023, 10:08 AM
  2. How often do you grease up the grease zerks in drive shaft
    By Burnerboy in forum Roadsmith Trikes
    Owners Forum
    Last Post: 03-20-2023, 07:33 AM
  3. grease fitting
    By Gold Nugget in forum Harley Tri Glide
    Last Post: 05-13-2019, 12:04 PM
  4. I found a grease fitting On my 2014 Trike
    By Side by side in forum Harley Tri Glide
    Last Post: 03-15-2015, 01:20 AM
  5. Universal Grease Fitting
    By Yogisan in forum General Discussion
    Last Post: 07-20-2011, 07:42 AM
