Likes Likes:  2
Thanks Thanks:  1
Results 1 to 4 of 4
Thread: Headlamp Visor (67752-77T) not fitting bezel (68051-08).
    30+ Posts
    Apr 2022
    Veuxhaulles sur Aube, France
    Default Headlamp Visor (67752-77T) not fitting bezel (68051-08).
    According to the HD catalogue and website headlamp visor 67752-77T fits bezel 68051-08 (with headlamp unit 68345-05A).
    The visor instructions say it fits all models equipped with 7” headlamps except with headlamp trim kits 69626-99,69627-99, 69733-05 and 69734-05.
    However, there is simply not enough space between the headlamp ring and the headlamp bezel to fit the visor. I can fit the visor to the top of the headlamp ring and attach the bezel at the top using the two rubber bumpers, but when I attach the bottom retaining screw to the bezel the retaining ring will not fit flush at the bottom with the headlamp unit/retaining ring assembly. I do not want to use too much force for fear of breaking the headlamp glass.
    Has anyone had a similar experience and found a solution?
    300+ Posts
    Mar 2018
    Waelder, Texas
Size:  757.8 KBI can offer this for a solution. This is 69734-05. It was pretty easy to install. I have no experience with your visor, but I’ve been pleased with this one.
    300+ Posts
    Mar 2018
    Waelder, Texas
    Also, I want to wish everyone Happy Thanksgiving!
    30+ Posts
    Apr 2022
    I attach two photographs of my newly installed visor (part number 67752-77T).
    The visor simply would not allow the bezel to fit correctly all around with the retaining ring as supplied.
    Eventually I had to cut out the top two thirds of the retaining ring (equivalent to the radius of the visor), and retaining the lower two thirds and two retaining screws.
    Only then could I insert the visor and fit the bezel correctly. Name:  IMG_1639.jpg
Size:  1,001.0 KBName:  IMG_1640.jpg
Size:  1.03 MBName:  IMG_1639.jpg
    All is now correctly fitted, as you can see.
  1. Harley Freewheeler - European model with no central headlamp lens - replacement?
    By lingone in forum Harley Freewheeler / Road Glide 3
    Last Post: 11-25-2022, 12:28 PM
  2. Tail light not fitting
    By BobH 4 in forum Honda Trikes
    Last Post: 03-18-2016, 07:23 AM
  3. New Custom Dynamics LED headlamp
    By Hrolfr in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-06-2016, 09:06 AM
  4. ****Special on Visor Headights & Headlight Relo Kits****
    By DK Custom Products in forum DK Custom Products
    Last Post: 01-20-2015, 12:08 PM
  5. Headlight visor
    By GARYD in forum Harley Trike Conversions
    Last Post: 02-26-2012, 06:33 PM
