Likes Likes:  3
Results 1 to 6 of 6
Thread: European Number Plate Holder and Light
    30+ Posts
    Apr 2022
    Veuxhaulles sur Aube, France
    Default European Number Plate Holder and Light
    The European number plate holder and light seems to be created to hold all the various different sized number plates used in Europe.
    On my French plated Harley Davidson this resulted (I think) in an oversized holder that was quite ugly (see attached photograph), so I replaced it with a simple numberplate attached directly to the boot/trunk/coffre, and illuminated by a Thunderbike single LED (photograph attached).
    I am very pleased with the resulting simple and clean look.
    20+ Posts TrailtrekerNJ's Avatar
    Jun 2017
    Dingmans Ferry, PA USA
    Does look cleaner.
    Is it required for the plate to be mounted in the center or could it be relocated to behind the wheel, like in U.S.?
    Name:  freewheeler license plate.jpg
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by TrailtrekerNJ View Post
    Does look cleaner.
    May be better to check with the DMV .
    30+ Posts
    Apr 2022
    Does look cleaner.
    Has to be in the centre to comply with French (and other European countries?), and the same applies to motorcycles. I have seen side mounted number plates on motorcycles here, but it has been confirmed to me that this is not legal. However, the Gendarmes here seem pretty relaxed about motorcycle regulations (unless you provoke them, of course!).
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by lingone View Post
    Seems to me that where you mount your plate shouldn't be big problem... ( I understand that there should be a light above the plate, so it can be seen at night....( I personally see no problem on where you have your plate mounted...........
    12/4/22
    Sep 2016
    Does look cleaner.
    Aaaaaaaa the old Abdow's "Big Boy" Hamburger sign...............I used to hang out there in my younger days....
    You just brought back some wonderful memories..............
    12/4/22
  1. license plate holder
    By leeekeee in forum Harley Freewheeler / Road Glide 3
    Last Post: 07-17-2020, 09:36 AM
  2. Replies: 3
    Last Post: 02-08-2019, 02:27 PM
  3. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  4. new motor trike and a trip the the southern European alps
    By extreme10 in forum General Discussion
    Last Post: 09-29-2014, 07:53 PM
