Results 1 to 9 of 9
Thread: Tire Size
    100+ Posts mcdonaldroadcapt's Avatar
    Oct 2010
    Canton, Georgia
    Default Tire Size
    I posted this under Harley Trikes with no response so I will try here. I am running 225/60/15 rear tires on my Trog. I want lower gearing without the costs of changing sprockets. My tires are needing to be replaced and I want to go to 225/50/15 to lower the ratio. Has anyone tried this combo? Also can someone do the math for me? I know bike will sit 1 3/4 inch lower but I can accommodate that with air suspension.
    Thanks for any help.
    Jim
    Default Re: Tire Size
    Quote Originally Posted by mcdonaldroadcapt View Post
    Iposted this under Harley Trikes with no response so I will try here. I am running 225/60/15 rear tires on my Trog. I want lower gearing without the costs of changing sprockets. My tires are needing to be replaced and I want to go to 225/50/15 to lower the ratio. Has anyone tried this combo? Also can someone do the math for me? I know bike will sit 1 3/4 inch lower but I can accomodate that with air supension.
    Jim
    Jim probably no one has done this. Sorry you need the circumference of the tires to do the calculations.
    Oct 2010
    Canton, Georgia
    Circumference of 225/50/15 is 74.92 inches. Can you calculate?
    thanks.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Jim
    The change from a 225/60/15 to a 225/50/15 will add a 6.9% gain in your speedometer reading, meaning that when your speedometer reads 60 MPH you will actually be running 55.9 MPH. There are several speedometer calibrators available, one of the better ones being the Speedo Tuner which sells for about $99 for the Big Twin HDs. Link Below.
    Speedo Tuner
    Oct 2010
    Canton, Georgia
    Thanks for the info. Will proceed.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    If you need any more size calculations try the site link below. Just plug in the tire sizes and it will calculate everything for you. Very handy little tool.
    Tire Size Calculator
    Oct 2010
    Canton, Georgia
    Thanks for info on site.
    750+ Posts
    May 2009
    Down South
    I remember posting on this topic elsewhere, but you can change gearing rather easily by changing tire aspect ratio. I shortened my gearing 4% by going to a rear tire 1-inch smaller in overall diameter. You will need to mind your ride-height and not go too far. A 1-inch overall reduction will lower the ride-height by 1/2-inch.
    Oct 2010
    Canton, Georgia
    Thanks. I finished the application from 225/60/15 to 225/50/15 and love the results. Sweet spot is where it should be and no bogging off idle. Speedometer off a little but who cares? Very well pleased and with two up and air bags pumped to 30 lbs no tail dragging.
  1. Trike Tire Size
    By crzrlou in forum Tires, Wheels, Brakes, Front End
    Last Post: 12-01-2021, 06:23 PM
  2. Unsure on Tire Size
    By robval87 in forum Honda Trikes
    Last Post: 01-19-2014, 11:29 PM
  3. Front tire size
    By alstrickland55 in forum Home Built Trikes
    Last Post: 07-19-2012, 07:31 AM
  4. Rear Tire Size
    By mcdonaldroadcapt in forum Harley Trike Conversions
    Last Post: 05-05-2011, 03:33 PM
  5. Tire size question
    By Big_Steve in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-03-2010, 09:43 PM
