Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  3
Thanks Thanks:  1
Results 1 to 3 of 3
Thread: Harley M8 Oil Flow Diagram
    Default Harley M8 Oil Flow Diagram
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Those passages are narrow which is the reason I had no qualms mounting the DK Customs oil filter relocation kit. It dosnt take a lot of oil pressure to squirt through those passages 15-20 PSI at warm idle. At the outboard bung below the oil filter I mounted the fitting for the A1 Cycle oil pressure gauge and snaked the cable up to the rear rocker box where the gauge mounts.
    100+ Posts
    Jun 2022
    South Carolina
    This illustration is for the Twin Cooled engine, the Oil Cooled engines have an oil cooler and oil passageways that run inside the cylinder heads to cool the exhaust valve area.
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
  1. Harley Davidson Cool Flow Fan P#26800128
    By windsurfed in forum Harley Tri Glide
    Last Post: 11-05-2020, 12:09 PM
  2. Full flow oil filters
    By hawkeyefxr in forum VW Powered Trikes
    Last Post: 03-10-2016, 01:42 PM
  3. Wire Diagram 2005 Goldwing Trunk.
    By Lone Wolf Top in forum Honda Trikes
    Last Post: 05-02-2014, 09:19 AM
  4. 2010 stallion wiring diagram
    By ODDOMAN in forum Stallion Trikes
    Last Post: 11-23-2010, 01:31 AM
  5. Wiring Diagram Info for 2008-2009 Stallion
    By fatherof5 in forum Stallion Trikes
    Last Post: 10-16-2010, 08:11 PM
