Results 1 to 4 of 4
Thread: V8 trike differential question
    Dec 2022
    Oakwood, TX Freestone
    Default V8 trike differential question
    Hello,
    I am narrowing a GM 8.5” 10 bolt for a SBC T350 trike build. I am building this one as narrow and short as I can. Is there a rear axle width that would be too short, or unsafe?
    100+ Posts
    Feb 2017
    DE
    I would look at boss hoss or v8 trikes, measure their stuff. I left mine wide.
    Left the 2;73 gears in it.
    I was thinking of doing 3 to5 shorter
    Post a sketch or pics when you get time
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Tommyathacker View Post
    Hello,
    imo i would not narrow it at all... i have built several trike all with car rears always irs for a better ride and will take more g force before lifting a wheel.
    i always end up pretty close to stock width. i was horsing around and did get one on 2 wheels scary again my opinion but the wider the better
    30+ Posts
    Jan 2013
    Slidell, LA
    Hello,
    The short answer is "yes", but specifying that width gets complicated because of all the variables like center of gravity, tire width, rim width and offset. I just built a chain drive differential/rear axle for a Sportster conversion and made it 38" wheel mounting surface to wheel mounting surface. I certainly wouldn't go any narrower on a trike with a V8 powertrain. Probably would go wider.
  1. Lehman Trike Differential Assembly for Sale
    By Lee H. Mann in forum Lehman Trike
    Last Post: 10-19-2023, 10:51 AM
  2. Lehman Trike MONARCH II Differential Assembly for Sale
    Last Post: 06-16-2021, 11:54 PM
  3. Motor Trike differential
    By lasso in forum Harley Trike Conversions
    Last Post: 07-13-2015, 07:17 PM
  4. Differential for custom VT750C trike conversion?
    By DianneB in forum Honda Trikes
    Last Post: 09-30-2014, 03:30 PM
  5. Greasing differential on rigid axle HD trike
    By engprosinc in forum Harley Trike Conversions
    Last Post: 07-24-2013, 07:53 PM
