Likes Likes:  8
Results 1 to 18 of 18
Thread: Led bulbs in Tri glide tail lights
    80+ Posts
    Apr 2016
    Little Egg Harbor, New Jersey,U.S.A.
    Default Led bulbs in Tri glide tail lights
    Have any of you just used a led bulb in your tail lights instead of changing out the whole assembly. Also did you have to use load equalizers for the 1157 standard bulb led replacement? I've a 2022 Tri glide and wondering if the load equalizers are necessary.
    No resistor required, tho you made need to run the 4 way flashers for a minute for the BCM to recognise the new bulbs
    make sure to use the red LED bulbs
    https://www.oreillyauto.com/detail/c...l8/3157rledbp2
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Quote Originally Posted by bowelder View Post
    On my 21 TG, it was plug and play.
    Mar 2016
    Georgetown, TX, US
    I looked through a number of posts going back a few years concerning the tail light bulbs and couldn't find any mention of the benefits of replacing the bulbs. Is there a benefit to replacing the incandescent bulbs with LEDs? Brighter? Cooler? Sexier? My trike is a 2016 and haven't had any problems.
    Quote Originally Posted by MSgtRick View Post
    Brighter, draw less power. last longer
    80+ Posts
    Apr 2016
    Thank you for your replies,as soon as I get a chance I'm gonna
    take a tail light off and give it a try. Thanks again.
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    I use these on my 2019, they flash three times then go solid. Less than $20 for a pair of them.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    150+ Posts windsurfed's Avatar
    Jul 2020
    Spokane WA USA
    Quote Originally Posted by Koolbreeze View Post
    I take it they are just plug and play? I mean, you just take the old bulbs out and plug these In?
    Stupid is a choice
    Dumb is not a choice
    Stupid can be fixed
    Dumb cannot be fixed.
    Oct 2018
    Quote Originally Posted by windsurfed View Post
    Yes, plug and play. However, if you plug them in and they don't work, reverse the bulb in the socket as LED's (diodes) are directional.
  11. #10
    Mar 2016
    Georgetown, TX, US
    I’m a sucker for new gizmos, thingys and doo-dads. After looking over the previous comments in this thread on LED tail lights I ordered the ALLA Lighting red LEDs. They’re definitely brighter and do have a distinct signal when using the turn signals. As mentioned before, the stop signal does flash three times before going solid. Pretty nifty. Thanks for all the hints. I’ll keep the old bulbs wrapped up inside my tool bag. Never know when they might be needed!
  12. #11
    Jul 2020
    Spokane WA USA
    I ordered mine and they are on the way
    Stupid is a choice
    Stupid can be fixed
  13. #12
    10+ Posts New trike's Avatar
    Nov 2022
    east springfield, pa. united states
    can you tell me what model year tri glide these have been used in. I have the 2018. main question is did it affect the radio , as far as static or anything like that. when i put LED lights in my older ultra classic it killed the radio with static.
  14. #13
    Oct 2018
    Quote Originally Posted by New trike View Post
    See Post #7, no issues with static.
  15. #14
    Feb 2022
    Larimore, ND, usa
    See my post in the Led tail light bulb thread. It killed my radio with static, was pretty bad. Mines a '21 trike.
  16. #15
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    Unfortunately this is a common issue with the "cheaper" LEDs. They produce a lot more noise due to weak EMI suppression. That's why I went with all Custom Dynamics in mine. If I had've went cheaper, with as many as I have added, I probably wouldn't be able to use my phone either. I just watched for sales or built up points at JP to get all of mine or used Harley gift cards I have been given. Sometimes it really is buy once, cry once.
    2016 Tri Glide, More DK than HD. Just shut up and ride.
  17. DKCustoms postbit
  18. #16
    Jan 2023
    PORTAGE, mi,usa
    personally , I did not find them to be any brighter than the stock incandecent bulbs. 2014 triglide
  19. #17
    300+ Posts
    Mar 2018
    Waelder, Texas
    We don’t know what you used, but some LEDs are not bright at all. Some are very bright but cause other issues like radio noise. Some will cause the indicators on the dash to hyper flash, which is not really a problem for me. Just have to do your homework.
  20. #18
    150+ Posts Colleydog's Avatar
    Feb 2018
    Kingsport, tn. Usa
    I agree with dokk, buy custom dynamics, might pay more but they are worth the money
    2018 115 anniversary Tri glide, 2 +2 narrow sweepers, DK comfort lift, DK tour pack relocation kit, pro action shocks, power vision, fuel moto air cleaner, s and s mufflers
  1. TG LED Tail Light Bulbs
    By DTR 11TG in forum Harley Tri Glide
    Last Post: 01-26-2015, 06:36 PM
  2. Which LED lights for the rear tail/brake lights
    By 470004 in forum Harley Trike Conversions
    Last Post: 11-20-2014, 08:13 PM
  3. Tri Glide LED Tail Lights
    By trikermutha in forum Harley Tri Glide
    Last Post: 05-12-2012, 06:56 AM
  4. LED tail light bulbs
    By scooty in forum Harley Trike Conversions
    Last Post: 03-29-2012, 06:43 AM
  5. tri glide tail lights
    By meredog in forum Harley Tri Glide
    Last Post: 11-26-2010, 04:51 PM
