14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Results 1 to 5 of 5
Thread: intermittent radio with headset
    Aug 2022
    Edgewater
    Default intermittent radio with headset
    my radio works fine till you use the head sets (new) then the intercom works between passenger and driver but the radio breaks up or the volume low .it had codes uo140, uo184 don't know what to look for ? 2014 tri glide
    Mike, these are BCM codes losing communication with the radio
    Do you have any warranty?
    The dealer can scan and reload software to correct these problems
    Many fault codes tied to the BCM can be traced to battery connections, clean and tight is always a first thing to check
    Aug 2022
    Edgewater
    no warranty. just bought this trike . what is the bmc? also what is the dtcs? it seams like something is lose, but i need a starting point . i have parts manual but don't see bmc or dtcs
    Quote Originally Posted by mrdej51 View Post
    BCM is the Body Control Module, DTC are Diagnostic Trouble codes
    All power runs thru the BCM, most all U trouble codes are related to lost communication,
    That said, the first place to look is battery connections, with the can bus electrical system the connections are critical
    Aug 2022
    Edgewater
    thanks i'll start their
  1. Intermittent electrical
    By Clevelandpat in forum General Harley Chat
    Last Post: 01-25-2022, 03:39 PM
  2. Intermittent Engine Stall, Shutdown
    By TejasRanger in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-30-2021, 04:05 PM
  3. Headset comparisons
    By Patches in forum Accessories
    Last Post: 01-29-2014, 09:40 PM
  4. Intermittent starting problem
    By Stalloin 146 in forum Stallion Trikes
    Last Post: 09-09-2011, 05:44 AM
  5. Headset/Radio Problem
    By tatco in forum Honda Trikes
    Last Post: 07-20-2011, 10:41 AM
