Likes Likes:  8
Thanks Thanks:  1
Results 1 to 4 of 4
Thread: rear brake switch replacement
    Aug 2022
    Edgewater
    Default rear brake switch replacement
    what are the steps for replacing rear brake switch on 2014 tri glide. you remove the floor board and unplug the switch,then what ? cant find any videos for rear master on tri glide
    Screw the switch out, do not apply the brakes with the switch out
    Replace the switch, if brakes are spongy bleed the rear brakes
    In this diagram # 22 is the rear switch
    300+ Posts
    florissant
    I had to do this and it's a bitch to do. but can be done. I removed the footboard and took the brake pedal loose and pin out. You can pull it out of the way just enough to remove the switch. Use needle nose to get the wires off. It is tight but can be done.
    The service manual wants you to remove the exhaust system to do this.
    hardheaded
    Aug 2022
    Edgewater
    it was tight and my fat fingers did not help. i removed the 2 bolts from the master and the clip on the down tube. gave me some extra room
  1. On/Off switch and Kill switch protocol
    By kodiak198 in forum Harley Tri Glide
    Last Post: 11-07-2019, 02:51 AM
  2. Cruise and rear brake switch
    By refuelman in forum Honda Trikes
    Last Post: 02-22-2017, 04:17 PM
  3. 2010 triglide brake switch replacement
    By pcmikey in forum Harley Tri Glide
    Last Post: 12-07-2012, 12:38 PM
  4. Brake switch recall...NO REAR BRAKES!
    By rwhgme in forum Harley Tri Glide
    Last Post: 11-18-2011, 04:13 PM
  5. t/g's rear brake switch recall
    By eagle1 in forum Harley Tri Glide
    Last Post: 10-23-2011, 04:56 AM
