Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  12
Thanks Thanks:  7
Results 1 to 20 of 28
Thread: Trike Oil Change
    40+ Posts
    Dec 2022
    Houston, TX, USA
    Default Trike Oil Change
    Good afternoon Y'all,
    I am making preparations for the first oil change on my trike. In all the video's I have watched it shows the bike being lifted and level when draining oil from the 3 drain plugs under the DCT model. In the attached photo you can see that I backed the rear wheels up on ramps and left the front tire on the garage floor. This gives me plenty of room to work under the bike. Is there a problem draining the oil with the bike in this unlevel position or should I use my jack to raise the front end as well? TIA.
    Paul
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    I can't imagine why you couldn't change everything with the trike sitting flat on the ground. I change mine on a lift but only because it makes it easier. To be honest I don't know about Honda Trikes.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    I have 2 sets of ramps and use 3 ramps and drive all 3 tires up the ramps.
    Works slick.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    250+ Posts
    Jan 2012
    oz
    Quote Originally Posted by Rogue1 View Post
    I agree, When changing oil, filter, coolant brake oil. My trike sits flat in the garage
    40+ Posts
    Dec 2022
    Houston, TX, USA
    Quote Originally Posted by BrokenBackJack View Post
    Works slick.
    I was considering buying another set of ramps and doing what you do. After watching a video of a guy who cracked his ground effects when driving down the ramps I reconsidered. I will have to check my clearance.
    40+ Posts
    Dec 2022
    Houston, TX, USA
    It is the "easy factor" that peaked my interest in lifting as well.
    Sep 2016
    Springfield, Mass. USA
    Very easy idea here; to lift up your trike to make it level......
    I cut three 4X4 boards 17inch long........Jack up the rear first and place a cut 4x4 under each rear wheel, (place your bike in 1st gear so it won't roll) and then jack up the front of the bike and place a 4x4 under the front wheel........Now your 4inch high'rr and can crawl under it easier, and place an oil catch container under it w/o any difficulties....... easy pessy!
    2/5/23
    40+ Posts
    Dec 2022
    Houston, TX, USA
    2/5/23
    Thanks Ronnie,
    I ended up leaving the rear wheels on the ramps and jacking up the front tire and placing two pave stones under the front tire. I removed the jack and the drain pan fit well with room to spare.
    Paul
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    1
    I have 2 sets of ramps and use 3 ramps and drive all 3 tires up the ramps.Works slick.
    This is what I did before I put a lift in my shop, I always try to level what ever I'm working on
    2019 Goldwing CSC
    Sep 2016
    Thumbs up
    Quote Originally Posted by Leaky Waders View Post
    Thanks Ronnie,
    Paul
    Paul,
    Sounds like you did what you had to do, and "cheap'rrr ($$$) than, what, I had suggested..........and it works! Good for you!
    2/10/23
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Paul
    The problem with trikes is not removing the oil or filter(s), but refilling the oil to a proper oil level. Rarely does a trike's engine sit at the same "slant" as an OEM Wing, thus a trike becomes challenging when topping the oil off to it's proper level.
    Sep 2016
    Quote Originally Posted by GoldWingrGreg View Post
    OMG Gregg,
    It good to hear from you again...........
    I have a 2010 Goldwing trike (Roadsmith) can you give me the actual amount of oil to use when changing both oil ~n~ filter ...(I always just put in the 3.9 QTS THAT THE BOOK CALLS FOR............ and always Honda oil like you quoted in the Gl1800 forum..
    PS: I'm Captron (gl1800 forum) wife ~n~ I visited you a few years ago at your shop and you were so nice.............. we will be back in Fla early November again for a few days vacation....
    2/13/23
    JustWings.com
    May 2016
    OMG Gregg,
    2/13/23
    Hey Ronnie ... how are things.
    As for your question, I have no idea. All trikes have a different forward/rearward slant or lean. For 5th gens, at my shop, on my shop floor, here is what we do. We take a stock OEM 5th gen Wing with a correct front tire and air pressure, and centerstand it ... on my floor. Then we lay a common 12" Stanely yellow level accross the right valve cover, and we look at the position of the bubble in the glass. We use the bubbles position as a referance. We do all trikes this way.
    When a trike comes in for an oil change, we place the same level on the right valve cover and lift either the front or rear to duplicate where the bubble is for a 2-wheel. We the adjust the oil level accordingly.
    Jan 2009
    MA,
    What would happen if you just Dumped in 4 full Quarts of oil ?
    JustWings.com
    May 2016
    If the trike sits low up front, and the oil was drained, it probably means that more then 4 qts was drained, and adding 4 is not enough.
    If the trike sits low in the rear, it probably means much less the 4 was drained, and adding 4 means it's overfilled.
    Sep 2016
    As always Gregg (I like your think'n) good idea, I have a level, and about to change out my oil again (I'm an oil changeOHLIC) and believe frequent, changes are good for the engine.......... The book claims every 8,000 miles...and I always follow what the booklet says, BUT 8 thousand miles is way to many for me, I usually change it at 3,000 or more often if I'm going on a long trip
    Ronnie 2/1/6/23
    JustWings.com
    May 2016
    Paul
    For us the biggest problem with doing oil changes on trikes, is not the draining of the oil, but refilling them to their proper level. For example, when their ass-end is up like that, they can "over drain," and adding the "recommended" amount after an oil and filter change can be way off.
    He we use a Stanley level across a valve cover to know. On our shop floor, we know where the bubble lands and a stock Wing, and "level" a trike accordingly.
    For example, about 3-weeks ago we had a 2-whl 5th gen in that had been lowered in the rear and also had a lowered ride-off center stand, and it came in for a tire and an oil change. The only way that I of to get the engine at its correct angle, to properly top off the oil was to lift the rearend with a gantry.
    Although I didn't charge the customer an add'l labor charge during this visit, I did advised him that next time their will be.
    40+ Posts
    Dec 2022
    Houston, TX, USA
    Thanks Greg,
    I ended up jacking up the front end to as close to level with the rear as my eyes could detect before draining and replacing the oil and filters. Next time I will use a small bubble level.
    Paul
  19. #19
    Jul 2012
    Talladega,Al 35160
    1
    Greg where does the bubble land? A picture would be great
    2019 Goldwing CSC
  20. #20
    JustWings.com
    May 2016
    Quote Originally Posted by woody View Post
    I took this a long time ago and have no idea what the orange lines are for. But here we put the level on the righ valve cover and jack to get the bubble as shown.
  1. My first attempt at an oil change on the GW Trike
    By paid4c4 in forum Honda Trikes
    Last Post: 04-08-2019, 09:22 AM
  2. Replies: 1
    Last Post: 05-07-2018, 07:10 AM
  3. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  4. Leaking oil after an oil change
    By trikerider55 in forum Harley Trike Conversions
    Last Post: 06-25-2012, 08:44 AM
  5. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
