Likes Likes:  12
Thanks Thanks:  7
Page 2 of 2 FirstFirst 1 2
Results 21 to 28 of 28
Thread: Trike Oil Change
  1. #21
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    Thanks I will have a look at mine today
    2019 Goldwing CSC
  2. #22
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Quote Originally Posted by GoldWingrGreg View Post
    QUOTE=woody;917904]Greg where does the bubble land? A picture would be great
    I took this a long time ago and have no idea what the orange lines are for. But here we put the level on the righ valve cover and jack to get the bubble as shown.
    Attachment 111791[/QUOTE]
    @GoldwingrGreg
    What about 2018+ Goldwing Trikes?
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
  3. #23
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Quote Originally Posted by BrokenBackJack View Post
    Havn't had to figue that out yet ... we've not had a 6th gen trike in.
  4. #24
    50+ Posts Deplorable's Avatar
    Nov 2021
    Hereford, AZ USA
    Attachment 111791
    I checked the oil today with my trike on a level floor. I put a level on the valve cover and the bubble was all the way forward. The level on the dipstick was right at the full mark. I raised the rear of the bike 3 inches to put the bubble at the same position as illustrated. The oil was very slightly below the full mark.
    At the next oil change I will measure how much oil was drained in both positions and report back. Seat of the pants observation indicates, on my trike, that it won't make much of a difference.
  5. #25
    Jul 2012
    Talladega,Al 35160
    Greg and Rob I found this interesting. I checked the level on mine and the bubble was all the way to the rear so I checked the oil level and then pushed the trike front wheel on a 2x6 I had and it put the bubble right at center rechecked the oil level and there is very little difference. So my opinion is if when checking my oil level I'll just keep it on the full mark, since there is a safety zone there that should be good.
    2019 Goldwing CSC
  6. #26
    JustWings.com
    May 2016
    On 5th and 6th gen Wings, hopefully when checking the oil level, everyones following the steps in the Owner's Manual. Start and run for 3-5mins, turn off, and check in 2-3.
  7. #27
    Sep 2016
    Springfield, Mass. USA
    Again, Thank you Gregg
    3/26/23
  8. #28
    Nov 2021
    Hereford, AZ USA
    Here are the results of my oil change on my 2012 Reverse Trike.
    Since my trike is lower in the rear I drained the oil with it on the ground.
    In order to get my trike at the same level as the one pictured I raised the rear of the trike 3 inches. And drained the rest of the oil. I got about 3 more ounces. I changed the filter.
    I put 1 Gallon of oil in it while the rear was raised. After idling to get the new oil throughout the system the oil level was right at the full mark. I put the bike back on the floor and the level was slightly above full.
    My conclusion, for my setup, is the difference between the two methods is minute. Not enough to go through the extra hassle.
  1. My first attempt at an oil change on the GW Trike
    By paid4c4 in forum Honda Trikes
    Last Post: 04-08-2019, 09:22 AM
  2. Replies: 1
    Last Post: 05-07-2018, 07:10 AM
  3. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  4. Leaking oil after an oil change
    By trikerider55 in forum Harley Trike Conversions
    Last Post: 06-25-2012, 08:44 AM
  5. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
