14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  13
Thanks Thanks:  4
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Hard pan rod
  1. #21
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Road couch rider View Post
    I can't believe HD would replace the hard pan rod after the bike is out of warranty. That happens in April 2023 so I probably won't be able to get enough miles on it to wear out the next one. I am itching to get out already as I got the stage 1 upgrade just before snow hit and only got to ride 30-35 miles. I can't wait for spring!
    Have that converstion with your dealer, find out what the warranty period is, get it in writting
    HD knows this is a high wear item, that said get it in writting
  2. #22
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    This gives me an idea, as soon as I get my bike back. I will check my panhard rod and if it has no slop, I will remove it and build a jig. That way I can rebuild it when it does go bad, along with all my buddies.
  3. #23
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Can anyone give me the size of the heim joints needed?
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
  4. #24
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    Quote Originally Posted by Rogue1 View Post
    Both are right hand thread from what I gather.
    QSC XMR-8, 1/2 X 1/2-20 Chromoly Teflon Kevlar Male RH Rod End
    https://www.amazon.com/gp/product/B0...9IC5BOYX&psc=1
  5. #25
    Oct 2018
    Ramseur NC USA
    Thanks Kool
  6. DKCustoms postbit
  7. #26
    5+ Posts
    Jan 2023
    Silt
    So I just got my tike back yesterday. The service manager had multiple discussions with the MoCo about the heim joint ssue. He said that 2020 trikes had a nylon washer on both ends of the rod. In 2021 and later models the engineers decided to eliminate those washers. I can't figure out how a nylon washer would keep the heims from wearing out but I ain't the sharpest tool in the shed! He says he thinks all 2021 and later trikes will have that issue. He also was willing to bet that 2024 will be sporting 2 ”extra" nylon washers. Apparently the MoCo was not aware of the problem until my machine? I am skeptical about having no more problems but I will find out.
  8. #27
    Oct 2018
    Do you know if the MOCO authorized the dealer to put the 2 nylon washers on your Panhard rod?
    Yep sure enough, there is a difference to the mounting hardware between the 2020 and 2021. Mine is a 2019 so it still has the washers. Going to have to check it anyhow for wear.
Size:  232.1 KBName:  2021.png
  9. #28
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    OK enough of this bullshit. The joints HD are using are dog crap ok? I wont stand for having what little intelligence I have being insulted by some kid ( thats right)at a dealership. Nylon washer or no- they are not the cause one way or the other.
  10. #29
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Bottom line, will replacing the factory heim joints fix the problem?
  11. #30
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Olddog View Post
    Yes, but it is a high wear item
  12. #31
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    I should have been more direct with my question. Would better quality heim replacements increase longevity. Thanks
  1. GL1800 Trike, Belly Pan and Heat
    By Yellow Trike in forum Honda Trikes
    Last Post: 07-08-2021, 08:32 AM
  2. pan hard rod
    By arnie in forum Harley Tri Glide
    Last Post: 04-25-2015, 02:13 PM
  3. Belly Pan on a GL1800 trike
    By Scalp Hunter in forum Honda Trikes
    Last Post: 11-24-2011, 10:44 AM
  4. 2011 Tri Glide - Loose oil pan!
    By ehroyal in forum Harley Tri Glide
    Last Post: 10-15-2011, 08:43 PM
  5. Oil pan leak tri glide
    By trikermutha in forum Harley Tri Glide
    Last Post: 07-12-2011, 06:54 AM
