Likes Likes:  6
Results 1 to 20 of 32
Thread: Trike not tracking/handling correctly…help!
    Jan 2023
    North Branford CT. USA
    Default Trike not tracking/handling correctly…help!
    Hey everyone. I’m new to the trike scene. Built a number of custom bikes but this is my first trike. Been working on this for a few years. I’m about 90% done. Took it out for a road test but it handles like shit in plain English. The front end wonders all over. It doesn’t shake, just wanders. I have a 45 degree rake, 3 inches of trail and a 30” front end. When the trike is parked I can shake it side to side. I know this is not right. The rear ended is centered. Everything is torqued to specs. HELP!!!
    I want to get this on the road this spring.
    Here’s a few pics.
Size:  1.03 MBName:  6CF48C63-3F91-4923-A7F0-3C0B608C34A3.jpg
Size:  1.08 MBName:  745410BC-08A0-47AC-BA01-88E68F5E098F.jpg
Size:  148.1 KBName:  65B8ABB4-2273-4D17-A9A9-8DFFDB79B180.jpg
    You might want to revisit the steering head bearing adjustment and think about a steering damper
    Try this for a re torque of tour stem bearings-torque the steering stem to 30-35 lbs. and go for a ride
    Run 36 PSI in the front tire and try 22-25 PSI in the rear tires
    750+ Posts
    Jan 2010
    east windsor ct
    a damper for a wander??? wobble yes wander no
    100+ Posts
    Feb 2017
    DE
    Jack would be correct on the first guess. Hold the triple to neck area, have someone else shake it.
    See if you feal any movement in the bearings, something could have moved? Bearing race had a smidgen of debri behind it? Lightly jack up under frame to see if neck to triples jiggle a bit
    Nice build,
    Jan 2023
    Default Thanks
    Thanks guys. I’ll take a look at the neck bearings as soon as I get a chance and update you. Does the trail seek to be ok at 3”?
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    I concur
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Quote Originally Posted by Oleschool View Post
    I dig it! Nothing like a custom chop.
    750+ Posts
    Jan 2010
    east windsor ct
    3" should be ok
    Jan 2023
    So I just went out to the garage and checked my tire pressure. My tire pressure was about 13 psi all the way around. I don’t believe that was the actual pressure when I took it out for a test ride last time but I can’t say for sure. it’s also been sitting for a while. I put 22 in the back and 36 in the front. I’ll check it again before I take it out for the next test ride and let you guys know how I make out It’ll probably be a while because I’m up here in the Northeast and we’re up for a cold spell.
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    That'd do it! I bought a bike (Not a trike) out of state several years ago. Flew to Texas to ride it home. Private party sale on EBAY. After completing the transaction, I moved the bike and it handled like a pregnant duck! TP was about 15 in both tires. Aired up and all was good. Good luck..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    100+ Posts
    Feb 2017
    DE
    I dumb it down, ruler under frame, turn right and left. Frame should stay same measurement, if you turn r of left, and it drops, steering back to center become difficult, because your lifting the trike.
    Trail n rake for dummys
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Funny,lookin at the tires it's obvious they're only riding on the center tread. Which would normally mean over inflation. Or the rims aren't wide enough for the tires.
    Jan 2023
    Sidecar. I see what you mean about the rear tires. I’ll have to look into that.
    Jan 2023
    So today was warm enough to go for a test ride. I jacked up the frame. No movement in the neck. I also turned the steering side to side and the frame stayed level. I put 36 PSI in the front twice and 22 in the red tires. The result It still handles like shit. It wonders and and shakes. Almost afraid to ride it. What am I missing? Can it be that the geometry is not ride? I’ve never built or ridden a trike before. Not sure how there supposed to handle but I’m sure not like this.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    At this point I would inspect all welded joints just to make sure there are no cracked welds. You stated that the axle was centered, just throwing this out there. But is it possible the axle is out front to back. Also do you have another set of wheels and tires you can try, never know you could have a bad belt in one tire. Just spit balling here.
    Maybe you can find somebody who’s been riding trikes for a few years and take yours out for a test ride and get their input…
    There’s been a few people new to Trikes, Who get on a Trike for the first time ride it, and state the same problems you’re having because they’re just not used to riding a trike ‘Trikes have their own geometry and ride nothing like a two wheeler…..
    Jan 2023
    I dont have another set of wheels. I’ll look over all the welds. I know this is probably not going to handle anything like a factory built trike but it doesn’t seem right. I’m going to see if there’s anyone local trike owner that can give me some input.
    thanks for all the advice guys.
    I do t have another set of wheels. I’ll look over all the welds. I know this is probably not going to handle anything like a factory built trike but it doesn’t seem right. I’m going to see if there’s anyone local trike owner that can give me some input.
    Mike…..Keep us informed….👍
  19. #19
    750+ Posts
    Jan 2010
    east windsor ct
    I do t have another set of wheels. I’ll look over all the welds. but it doesn’t seem right. I’m going to see if there’s anyone local trike owner that can give me some input.
    what exactly is it doing?
    wondering how u calculated 3" of trail.. are the trees raked?
    "I know this is probably not going to handle anything like a factory built trike"
    dont be too sure of that!
  20. #20
    Jan 2023
    For the trail I measured straight down from the center of the axle and then a straight line following the angle of the center of the neck to the ground. The distance where the two points contacting the ground was 3 inches. Running a 45 degree total rake. 42 in the frame and 3 in the trees. Also running a DNA rear end. The frame is rigid but I’ve got shocks mounted on seat.
    Cant keep it in a straight line.
  1. fuel gauge not reading correctly
    By rbvicar in forum Stallion Trikes
    Last Post: 08-17-2021, 06:06 PM
  2. Rear brakes not working correctly
    By Wayne Harmsen in forum Honda Trikes
    Last Post: 05-30-2014, 04:08 PM
  3. Fuel Gauge Not Reading Correctly
    By aussie in forum Harley Trike Conversions
    Last Post: 12-14-2013, 11:52 PM
  4. Real-time GPS tracking via the web
    By JohnC in forum General Discussion
    Last Post: 09-20-2013, 07:21 PM
  5. How to have a Triker Breakfast..."correctly"
    Last Post: 08-11-2010, 04:50 PM
