BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 32 of 32
Thread: Trike not tracking/handling correctly…help!
  1. #21
    100+ Posts
    Feb 2017
    DE
    When i cross a steel bridge, yup wander. Groves in pavement, stuff like that.
    We all know riding center on tire, vrs edge, back to center, causes that.
    Assuming you tire is round, nobody puts a flat tire on front, 😆
    The ideal you say you can shake side to side, sitting there, if front is tight
    Then are you rear axels sliding? A c clip style rear? Worn spiders , side gears, letting axels move?
    Back to rake , trail, im used to seeing 3 to 7 degrees in triples. Since your front axel is directly inline with tubes, how much tripple is in it,?
    My ole ironehourse was 7 degress.
    But it didnt wander at stock, it was hard to bring back to center.
  2. #22
    10+ Posts
    Jan 2023
    North Branford CT. USA
    I’ve been on a steel bridge and grooved pavement on my bikes. I know that feeling.
    the feeling I’m getting is a very unstable feeling.
    Everything is new on the build. Nothing should be worn. The axles is welded is in place so that won’t be sliding.
    im not sure what you mean by how much triple is in it. The frame has 42 degrees and the trees have 3.
  3. #23
    10+ Posts
    Jan 2023
    Took a couple of measurements this morning. Not sure if this makes sense. From front center point to outside front edge of the rear tires measure the same. Used a large square for the measurement. Name:  080FDABB-3D93-4EF1-ACFA-FBC122A8021D.jpg
  4. #24
    100+ Posts
    Feb 2017
    DE
    Quote Originally Posted by Oleschool View Post
    3 degress in tree, ? That should be fine
    Axel(s) welded
    Im not the best for formal wording sometimes
    Axel, shafts are inside of the housing
    I asume you welded housing, not welded a spool inside it?
    Or you did weld up the spiders?
  5. #25
    100+ Posts
    Feb 2017
    DE
    I tried to pm you, im not allowed. Lol
    Sometimes, a 20 min phone chat, is quicker
  6. #26
    750+ Posts
    Jan 2010
    east windsor ct
    i have an auto cad file that i use to lay out trail... with only 3 in the tree at 45 total i am guessing your trail is quite a bit more than 3 inches either way that should make it want to go straight. not wander
    tough for me to get out during the daylight... any way you could trailer it up to east windsor more than happy to check it out its about an hr
    860 six two three 2 five 4 seven
  7. #27
    10+ Posts
    Jan 2023
    Thanks for the offer guys. I’m going to look at a couple of other things when I get a chance and then give you a holler.
  8. #28
    100+ Posts
    Feb 2017
    DE
    Detroit locker, or welded spool, would give a wild at times ride
    Ask me how i know...........
  9. #29
    750+ Posts
    Jan 2010
    east windsor ct
    any update on this??
  10. #30
    100+ Posts
    Feb 2017
    DE
    Quote Originally Posted by stacebg View Post
    Must have been a simple, oh sh●t. I left that loose. Nice build, no reson for it being unstable
  11. #31
    80+ Posts Jd1a's Avatar
    Oct 2018
    Waddell, AZ USA
    Needs more trail, 3" is for a sport bike. IMO.
  12. #32
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Jd1a View Post
    that would be true on 2 wheels
    personally i find between 1-1/2 and 2-1/2 inches works best
  1. fuel gauge not reading correctly
    By rbvicar in forum Stallion Trikes
    Last Post: 08-17-2021, 06:06 PM
  2. Rear brakes not working correctly
    By Wayne Harmsen in forum Honda Trikes
    Last Post: 05-30-2014, 04:08 PM
  3. Fuel Gauge Not Reading Correctly
    By aussie in forum Harley Trike Conversions
    Last Post: 12-14-2013, 11:52 PM
  4. Real-time GPS tracking via the web
    By JohnC in forum General Discussion
    Last Post: 09-20-2013, 07:21 PM
  5. How to have a Triker Breakfast..."correctly"
    By skuuter in forum General Discussion
    Last Post: 08-11-2010, 04:50 PM
