Likes Likes:  5
Thanks Thanks:  1
Results 1 to 14 of 14
Thread: No Power to bike
    20+ Posts TrailtrekerNJ's Avatar
    Jun 2017
    Dingmans Ferry, PA USA
    Default No Power to bike
    Bike has been on trickle charger.
    Went to start bike and engine turned over but did not start. After a couple of cycles, I let everything settle and tried again.
    This time I heard a loud click from left side, everything went dead and there was a smell of burning wire.
    I checked all the fuses, and all appear intact.
    Tried Advanced search but too many variables come up.
    Made an appointment with local HD dealership to pick up for diagnostic check.
    Trying not to get dis-heartened, but getting ribbed by the "told you so" of non-Harley riding friends is making me question my decision of purchase.
    Glad it's not full riding season.
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Quote Originally Posted by TrailtrekerNJ View Post
    Bike has been on trickle charger. Went to start bike and engine turned over but did not start. After a couple of cycles, I let everything settle and tried again. This time I heard a loud click from left side, everything went dead and there was a smell of burning wire. I checked all the fuses, and all appear intact. Tried Advanced search but too many variables come up. Made an appointment with local HD dealership to pick up for diagnostic check.Trying not to get dis-heartened, but getting ribbed by the "told you so" of non-Harley riding friends is making me question my decision of purchase. Glad it's not full riding season.
    Check your main fuse with a meter. It may look good, but doesn't mean it is. What year is your Freewheeler?
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    How old is the battery?…. and you say trickle charger is it a trickle charger or a maintainer big difference?
    2019 Tri-Glide.......
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    That sucks, how old is your battery?
    Have it load tested , it is possible the current draw caused the starter to overheat ( like a dead short
    I would have the battery load tested, if it is bad you may save yourself some aggravation and down time @ the dealer
    Best of luck and check back in
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    This could be diagnosed in short order but since you deemed it unnecessary to provide as much information as possible-enjoy your visit to the dealer.
  6. #6
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by JTJersey View Post
    This is very good advice, pull the fuse out noting how well it fits in the contacts
    Clean the blades thoroughly, use a pick tool to clean the female mating pins before reinstalling the fuse making sure it is once again a tight fit
  7. #7
    Jun 2017
    Removed main fuse, cleaned all contact area, continuity check, re-installed, still no power.
  8. #8
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    When you say "no power" do you mean nothing even lights up on your dash when you turn it on, or the starter isn't engaging?
  9. #9
    Jun 2017
    Not a thing came on, no power period.
    Service Dept. got back to me saying that one cell of the battery was dead.
    Current battery came with bike, which is a 2015.
    Couldn't determine if it was the age of battery, defective battery or bad "Battery Tender" that affected the battery cell.
    Installed new battery, bike started right up.
    They tested to see if the after-market batwing fairing radio was drawing on battery.
    Came back negative on power drain.
    I'm not a bike mechanic so I hope the problem is resolved for riding season.
  10. #10
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Batteries, don’t last forever as far as bad cell goes. It’s nothing unusual that’s what happens to older batteries that’s why a lot of people were asking you about your battery.
    As the first thing to suspect…
  11. #11
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Always start at the source( the battery), you can solve most of your starting issues, no starts, slow starts, no power by load testing your battery
    A poor mans load tester, hook up a voltage meter to the battery, turn ignition on with head light on, observe voltage, press starter, if voltage drops below 10 volts and continues to drop, replace the battery
    Modern day engines require at least 10.5 volts to fire the ignition system let alone crank the engine
    On Twin Cam and M8 bikes don't even think of a kick starter, these engines require up to 2 full revolutions of the engine to light the fire
  12. #12
    150+ Posts
    Apr 2018
    Cordes Lakes, AZ
    I I'm reading your comment correctly, that battery was eight years old. I'm really surprised it made it this far.....
  13. #13
    Jun 2017
    I'll add this info to the maintenance manual I am creating for future "occurrences".
  14. #14
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Just follow the Law of Parsimony.......IE; The best Solution is to go to the easiest thing to change first......
  1. Video - Inexpensive Mod Install - More Power & Your Bike Will Love It
    By DK Custom Products in forum DK Custom Products
    Last Post: 02-15-2023, 01:44 PM
  2. Power to the lighter/power port on fairing.
    By Rmitchell55 in forum Harley Tri Glide
    Last Post: 10-20-2017, 05:59 PM
  3. Power...Power, I need more power
    By SJR in forum Harley Trike Conversions
    Last Post: 08-14-2011, 10:37 AM
