Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  11
Thanks Thanks:  1
Results 1 to 11 of 11
Thread: Harley Tri Glide Axle retainer plates
    30+ Posts
    Aug 2019
    Alcalde,New Mexico United States
    Default Harley Tri Glide Axle retainer plates
    Hello Fellow trikers
    Hope everyone is doing well in 2023. OK; so my question is how to check if the AXLE RETAINER PLATES on the Harley Tri Glides are going bad? I have a 2019 Tri Glide with 20,000 Miles I am getting ready to do the 20,000 Mile service
    and would like to know if I need to replace AXLE RETAINER PLATES, if so; I will need to order the Plates From DK Custom before scheduling the service appointment.
    I want to thank everyone in advance for you input on this situation.
    El Lobo
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    Quote Originally Posted by El Lobo View Post
    Hello Fellow trikers, Hope everyone is doing well in 2023. OK; so my question is how to check if the AXLE RETAINER PLATES on the Harley Tri Glides are going bad? I have a 2019 Tri Glide with 20,000 Miles I am getting ready to do the 20,000 Mile service and would like to know if I need to replace AXLE RETAINER PLATES, if so; I will need to order the Plates From DK Custom before scheduling the service appointment. I want to thank everyone in advance for you input on this situation. El Lobo
    El Lobo,
    The AXLE RETAINER PLATES installed at the factory were going bad as soon as you rode your Tri Glide out the dealer's door! Additional miles just made them worse. It is an easy Remove and Replace (if you have a bearing press, it's even easier!). I did my own Remove and Replace, but had a local indie press the bearings. Most difficult part of the job was jacking the TG up and removing the wheels. Total cost for me? Under $300, using the DK kit.
    2013 Tri Glide Ultra Classic (FLHTCUTG) DK Oil Cooler/Relocation Kit DK Custom Tank Lift Kit DK EBS Kit K&N A/C in Stock Airbox Convertible Comfort Lift Kit w/ 14" Pro Action Shocks
    Vance & Hines Monster Ovals behind OEM decatted header Motor Trike Mechanical Reverse DynaJet Power Commander V
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Jack up your trike, grab the rear wheels 1 at a time, move them in and out
    If they have movement they are already wearing and causing damage
    There should be no in and out movement and no noise
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    on my 2020, they were bad 2 yrs ago. Had the DK plates installed. They are so much thicker than the originals . Well made. I had less than half the miles you have and they were already bad. Don't wait too long. Don't forget to replace the bearings also.
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    I changed the retainer plates on my 19 tri glide at about 22,000 miles. They were definitely warped. I put them on a surface plate and it was easy to see. I took the axles out myself and had an automotive machine shop install the new bearings. The old bearings weren't bad but I changed them because I was in there. It's a good move. I put the DK plates on and should not have to worry about it.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
  6. DKCustoms postbit
  7. #6
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I replaced the ones on my 2017, if you are planning on keeping your trike for the term it is a wise investment. I took Jack Klarich's advise and hand repacked the bearings before I had them installed.
  8. #7
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    Definitely get the DK Customs plates. I replaced mine at 5000 miles and I was already getting grooves in the stock plates. And this was in prairie riding with very little cornering.
    The factory plates are JUNK.
  9. #8
    Oct 2018
    Ramseur NC USA
    Quote Originally Posted by Rogue1 View Post
    I had no indication they were bad. I didn't know until I took it apart and put the plates on a surface plate.
  10. #9
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    So is there an imminent danger of running the stock plates? I have 32000 miles on my 14
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
  11. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Notgrownup View Post
    No, but over time the score marks will continue and axle end play can increase
  12. #11
    Oct 2021
    Snow Hill NC USA
    I’ll check the next time I have it on the Jack in the shop.
  1. ***DK Custom-Axle Bearing Retainer Plates for Tri-Glide & Freewheeler***
    By DK Custom Products in forum DK Custom Products
    Last Post: 01-26-2023, 02:18 PM
  2. DK Custom's New Report on Trike Rear Axle Bearing Retainer Plates!
    By DK Custom Products in forum Harley Tri Glide
    Last Post: 10-21-2020, 04:03 PM
  3. Replies: 0
    Last Post: 12-04-2018, 01:03 PM
  4. Replies: 1
    Last Post: 11-27-2018, 01:59 PM
  5. Rear Axle Bearing Retainer Plates
    Last Post: 06-22-2018, 09:45 PM
