Likes Likes:  4
Results 1 to 13 of 13
Thread: Battery issue
    Feb 2023
    Vermilion
    Default Battery issue
    Question, Has anyone here relocated their battery from the side compartment to the rear lower trunk? I have thought about this, but was wondering if there is an aftermarket battery box small enough for a MC battery. It's a real pain hooking up the battery tender on the Roadsmith trike kit and am wondering if anyone has thought this out. Thanks
    Frank
  2. Roadsmith banner
  3. #2
    Quote Originally Posted by firespot View Post
    Frank
    Frank welcome to Trike-Talk............The easy way is to just put a pig tail on your battery and run it to a spot where you can just plug the tender in this way you don't have to get directly to the battery to plug the tender in any more...
  4. #3
    Hi Frank, to Trike Talk and your first post
    What Bob sad
    Easy to install a battery tender pigtail to your battery, once you decide to do this you may want to have your battery load tested first so you do not have any surprises with a bad battery
    Clean the battery connections good, make sure the battery is secure( not bouncing around, this will lead to early battery failure)
  5. #4
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Frank
    Perhaps I missed it - what trike do your have? If a recent Harley, there is probably already a tender plug.
    I agree with others - plus, I recommend adding a jumpstart harness (cost about $10) just in case you need it.
  6. #5
    Quote Originally Posted by cycle7447 View Post
    He has a 2014 Goldwing..
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Thanks - see it in his profile now. Wing connections are easier than Harley
    Sep 2016
    Springfield, Mass. USA
    I have the pig tail on my Goldwing (Roadsmith) trike........... I use it to also plug in my battery maintainer, every winter season while the trike is sitting in my garage
    2/16/23
    May 2023
    Charlottenburg, Tx, USA
    Default Jump start harness?
    Hey, What is a jump start harness? I’m new to trikes. Can you send me a link to one? In all my life I never heard of such a thing. sure sounds like it would come in handy. I’ve already had some experience with removing those side panels on the Goldwing over the battery and its a pain. Service thru a pig tail and wiring harness sounds good to me.
  10. Roadsmith banner
  11. #9
    Quote Originally Posted by Lazarus View Post
    Just Google pig tail for a motorcycle battery…👍..
  12. #10
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    You can get this from Amazon. By using this, you can connect the wires to your battery. If the battery fails, you can connect this to a jumpstart kit and jump the bike.
    In addition, you can also use the connector to make it fit your battery tender - so, this does the job of two things. Make sure you use the extra plug to connect to the tender
    LIXINTIAN 10AWG Connector Cable, 1.3ft EC5 Female Plug to O Ring Terminal Cable, 5.9in EC5 Male to SAE Power Automotive Adapter Cable, with 1 SAE Polarity Reverse Connector
  13. #11
    May 2023
    Default Pig tail for battery
    I know what a pig tail is, just didn’t know what you meant, by attaching it to a jump start harness. Apparently you can jump start with a pigtail? I’ll check it out on Amazon.
  14. #12
    Sep 2016
    Thank you 7447
    6/27/23
  15. #13
    Sep 2016
    Thank you 7447
    6/27/23
    I NOW have this pig tail installed on my battery...............YEA! battery "maintainer" just connects, easy peasy, too it. ALL SET NOW!
    Thanks everyone! {7447}
    10/21/23
  16. Roadsmith banner
  1. Old Battery vs New Battery
    By Baldy_54 in forum Honda Trikes
    Last Post: 12-05-2023, 10:15 AM
  2. Battery life and battery purchase
    By pcombe in forum Harley Trike Conversions
    Last Post: 02-21-2019, 05:53 PM
  3. URGENT!!!!! Lighting Wiring Harness Short Issue
    By Gorilla in forum Stallion Trikes
    Last Post: 12-27-2008, 06:45 PM
  4. cruise control issue
    By cowboy in forum General Discussion
    Last Post: 04-07-2008, 05:04 PM
