Likes Likes:  6
Results 1 to 9 of 9
Thread: How connect air horn to existing 12v wiring?
    Mar 2023
    Ohio
    Default How connect air horn to existing 12v wiring?
    Hi all. Got a 2006 rewacy VW Trike with 1600 aircooled. I need to replace existing 2-wire 12v horn (1 wire is "hot" permenantly) so I assume the other side is ground??? Not a clue!!!
    I have a little 12v air horn with built in compressor - 2 terminals.
    How do I connect the existing 2-wire horn wiring from trike via a 4 pin relay to the new horn 2-pin wiring?
    I got the relay fitted with battery 12v power & earth - but no matter how I play about with the other 2 terminal/wires I cant work it??? Not very electrically minded. And yes, the hown does work if simply connected straigh to battery live/eart so I know it works.
    An help or a little diagram greatly appreciated folks.
    Quote Originally Posted by nzollie View Post
    Ollie….
    I can’t help you on the horn, But I can Welcome you to Trike Talk..👍👍..
    Mar 2023
    Ohio
    Default Thank you
    Sorry - had been a member previous but could not remeber my log in info....
    Mar 2023
    Ohio
    Looking athis schematic brings 2 questions:
    1) does this mean the 2-wires from original vehicle loom are basically "looping" through the horn??
    2) if yes, then 85 and 86 would be the 2-original wires in these positions? so the 12v fused is the "hot" wire of those 2????
    If you didn’t want to use the existing wiring, I would hook it directly to the battery with an in line fuse and an interrupter button..IE press the button to activate the horn.. i’ve done that many times with vehicles when monkeying around with adding extra horns and fog lights…
    Just to add, that’s how I hooked up Framm Air horns to my 71 Volkswagen Beetle..
    It looks like #87 is looped + feeding both horns, the other wire is the ground
    That wiring is good to go for your new horn, you could test that theory with a battery charger and jumper wires before actual install on your trike
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default AirHorn
    Name:  Air Horn wiring.jpg
Size:  105.8 KBWill this help? I'm the last person you will ask for wiring help, still working on mine...
    JakeJacobsen@Pinterest.com
    Mar 2023
    Ohio
    Default Thanks
    Many thanks folks - sorted - and loud! 120db on mobile app!
    May 2016
    Hemet, Ca. USA
    Default 120bd
    Here's 300 DBs When I hooked it up for trial, OH SHEEEEET!!! Wife came running to the Garage , neighbors sticking their heads out the windows...NO ONE WILL PULL OUT IN FRONT OF YOU WITH THIS eBay Horn, I love it...Name:  Horn 12V 300DB-LOUD.jpg
Size:  56.2 KBEDIT: Maybe not use the finger anymore...
  1. Push to connect 1/8" air line fittings.
    By Oldrodder in forum Harley Trike Conversions
    Last Post: 07-19-2022, 05:44 PM
  2. Replies: 15
    Last Post: 03-04-2015, 05:46 PM
  3. Replies: 4
    Last Post: 09-22-2012, 08:09 AM
