Likes Likes:  4
Thanks Thanks:  2
Results 1 to 4 of 4
Thread: Reprograming security code
    50+ Posts
    Strelnikov's Avatar
    Feb 2023
    Monticello, IL
    Default Reprograming security code
    Having some problems with this. Following instructions in manual results in nothing except turning on and off the left turn signal. The "reprogram code" message never scrolls across odometer.
    Any advice?
    Sufficient unto the day is the evil thereof. - Jesus Christ, Sermon on the Mount
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Strelnikov View Post
    Any advice?
    If you are talking about reprogramming the PIN for you to use in case of not having a working FOB with you....below is a video that may be helpful.
    Every bike is a bit different, but principle is the same. One thing we have found is you gotta be pretty quick at pressing the buttons for it to work.
    www.DKCustom.com
    Is this in your owners manual
    To reset the code with a HFSM equipped bike (no button fob), you will:
    1) Have your key fob near the bike
    2) Set your kill switch to off
    3) Quickly turn the ignition switch on
    4) With kill switch in off position; will turn switch in and off twice then to
    on (run, off, run, off, run)
    5) Immediately press and let go of the left turn signal switch twice
    (press, let go, press, let go)
    6) Press and let go the right signal once
    7) Current PIN number will be displayed on odometer
    8) Change the PIN by pressing the left signal until the desired number is
    reached
    9) Press the right signal to cycle to the next number and repeat step 7
    10) To set code; turn kill switch to off and ignition to off
    NOTE: Steps 3 through 6 must be completed in quick succession of each other.
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Who comes up with these things? I know we all want our pin's to be secure, but this requires everything except a full moon on a Thursday in May. That procedure did work for me. Tried it a while back just because.
  1. Security system
    By Nana in forum General Discussion
    Last Post: 01-04-2013, 09:30 PM
  2. Security System Smart Siren
    By Lakeman in forum Harley Trike Conversions
    Last Post: 01-21-2012, 07:11 AM
  3. security system lamp(key)comes on
    By roadkill in forum Harley Trike Conversions
    Last Post: 08-06-2009, 10:47 PM
  4. Tri-Glide security Siren
    By v2plus15 in forum Harley Tri Glide
    Last Post: 07-30-2009, 03:19 PM
  5. Social Security and coming full circle
    By Calman in forum General Discussion
    Last Post: 07-08-2009, 08:12 PM
