LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  7
Thanks Thanks:  4
Results 1 to 20 of 23
Thread: Electrical Issue 2022 TriGlide
    30+ Posts aviscomi's Avatar
    Mar 2023
    Levittown, PA, USA
    Default Electrical Issue 2022 TriGlide
    Need some assistance. I was changing my levers on my 2022 Tri-Glide. I did the clutch side first and tested, everything was okay. After doing the brake side I developed an electrical issue.Headlamp, tail lights, brake light (if rear brake pedal is applied) and fuel pump work fine. Nothing else does (i.e. No start, no radio, no horn or turn signals). I checked all the fuses and they all look fine. I even replaced them.
    Any thoughts?
    Run a scan on your trike first, it may show a fault code so you can identify what system is causing the problem, it should also ( if codes are detected give a part number) for easier diagnostics
    https://www.wilkinsharley.com/--Chec...rley-Davidsons
    Mar 2023
    Levittown, PA, USA
    Normally I would try that, but I am not getting any power to the display/speedo
    Quote Originally Posted by aviscomi View Post
    Any thoughts?
    Those brake switch's break / damage easily they are very delicate, You might need a new one..?
    Mar 2023
    Levittown, PA, USA
    Possibly, but if broken that would not cause all these issue. Typically when they break, the brake light stays on.
    Did you take the switch half's apart when doing the job?
    See # 17 below
    Mar 2023
    Levittown, PA, USA
    See # 17 below
    Yes I did
    Open them back up and check for pinched wires, pay attention to the ribbon wire @ the bottom of the RS switch
    # 4 in the diagram
    Mar 2023
    Levittown, PA, USA
    # 4 in the diagram
    I gave up and I'm going to have the dealer pick it up tomorrow or Saturday. I'm actually pretty mechanically inclined and do well with electrical crap, but this 1 has me stumped.
  11. #10
    Post back when you find out, this will surely help others in the future
    Best of luck to you
  12. #11
    Mar 2023
    Levittown, PA, USA
    Best of luck to you
    Sure thing
  13. #12
    10+ Posts gtrb's Avatar
    Jan 2023
    Wisconsin
    I had something like that happen to me when I installed heated grips on a 05 ultra a few years back. The speedometer, tach, the lights in these gauges, directional's, horn and radio controls on the handle bars were all dead. None of the warning lights in the speedo would work. It would not give any codes but the 4 ways would flash 6 times when the ignition was turned on. It ended up being blown fuse for the accessories. The grips were wired into the accessories plug in the fairing and one of the wires got pinched and shorted out in the handle bar. This probably wont help you but these things can be a big pain. If you have a short, they can do funny things.
  14. #13
    Mar 2023
    Levittown, PA, USA
    Problem solved...pinch wire in the clutch side. Bad news is that I need a clutch safety switch
  15. #14
    Don't feel too bad.......There have been numerous safety switches on the handle bars that had to be replaced after work was done on the bars...Like putting on new grips or new levers...ETC.....Those switches are delicate...
  16. #15
    The wiring on these newer models is much more complex
  17. DKCustoms postbit
  18. #16
    100+ Posts
    Jun 2022
    South Carolina
    Why must the switch module be replaced if the issue was a pinched wire?
    The wire harness is not part of the module...
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
  19. #17
    Mar 2023
    Levittown, PA, USA
    Quote Originally Posted by Dan SC View Post
    Actually all is fine now. I did not realize that in order to start the Tr-Glide in gear that both the clutch & brake must be applied.
  20. #18
    Doesn't make any sense ......If you go back it your first post you say....No radio no horn no turn signals ??....The cluch and brake Do not need to be applied for them to work.............
  21. #19
    Mar 2023
    Levittown, PA, USA
    The main/only issue was a pinched wire at the clutch perch which was cause al of the electrical issues. After resolving that issue, I tried to start the bike in gear with only the clutch engaged. At that point I assumed I had screwed up the clutch safety switch not knowing that I also had to apply a brake.
  22. #20
    Thanks for Splaining it more better..
  1. 2018 DCT CSC Encore electrical issue
    By russ067 in forum Honda Goldwing Gen3 2018 & UP
    Last Post: 02-08-2022, 11:32 AM
  2. 2014 Triglide electrical problems
    By cowboy472 in forum Harley Tri Glide
    Last Post: 06-27-2021, 12:20 PM
  3. Electrical Issue-need some help
    By grumpy in forum Honda Trikes
    Last Post: 07-24-2018, 05:45 PM
  4. Electrical accessory plug issue
    By ofscout in forum Harley Tri Glide
    Last Post: 05-28-2015, 11:41 PM
