Likes Likes:  9
Results 1 to 12 of 12
Thread: Harley Cool Flow Fan
    10+ Post Club
    Apr 2017
    Davenport, Fl 33937
    Default Harley Cool Flow Fan
    Anyone purchased and installed this fan from Harley Davidson for 2017 Tri Glide? Living in Florida and want something to reduce the heat when stuck in traffic. This one directs the heat to the ground versus ones that drive the heat from the left to the right. Appreciate any suggestions. Thanks in advance.
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    2013 Tri Glide Ultra Classic (FLHTCUTG) DK Oil Cooler/Relocation Kit DK Custom Tank Lift Kit DK EBS Kit K&N A/C in Stock Airbox Convertible Comfort Lift Kit w/ 14" Pro Action Shocks
    Vance & Hines Monster Ovals behind OEM decatted header Motor Trike Mechanical Reverse DynaJet Power Commander V
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Quote Originally Posted by chiefdave View Post
    I have one on my 2021 Ultra Trike - last year was the first riding season I used it. I did notice a difference.
    Let mine on auto.
    150+ Posts hydraglide's Avatar
    Dec 2021
    Woodridge,Il USA
    I use both the Harley Coolflow fan and a set of Love Jugs… I rode all last summer with this set up (I run a Stage II as well) and found the combo to work very well. I also ride with JES Fork fangs, which is the reason I added the auxiliary fans.
    No problems at all.
    I will report later (once I get out and the weather heats up) on how my set of Design Engineering heat shield liners work to further reduce felt heat.
    I anticipate good things…
    https://www.designengineering.com/he...tock-headpipe/
    Live Everyday Like It's Your Last... Because One Day It Will Be...
    2021 Billiard Red Tri-Glide • 1999 Ultra Classic - Stage 2, 6 Speed (Gone) • 1995 Softail Nostalgia (Gone) • 1977 Superglide - Chopped (Gone)
    • 1976 Liberty Edition Sportster (Gone) • 1949 Hydraglide Panhead - Fully Restored (Gone)
    100+ Posts
    Apr 2022
    Bridgewater, New Jersey, USA
    I picked up my '20 in December of '21. During the winter I added DKs tank lift & air defectors. Decatted the headpipe and wrapped them in titanium header wrap. Added the 1" floorboard extenders. Removed the left mid frame air deflector. Also purchased a Cool flow fan but didn't install it. That was a very hot summer here. I road as much as I could in the heat of the day. In traffic, back roads, highways, I never felt much heat. The more interesting thing is I never mentioned the heat issue to my bride to see what she felt about it without any bias. She said it was better then my old Ultra. Didn't really feel anything. I was very surprised as I had heard the passenger heat was more an issue on the trike because of the cat position on the trike. So I never installed the Coolflow fan. I didn't think it would be necessary with the other things I did and I was right. I installed a FP3 and kept watch of the engine temp in case I needed to install Love Jugs. Temps never got over 270. Not something I'd worry too much about. Just keep up with oil changes.
    All that said, I'm in New Jersey. You're not. Our summers are just as hot as yours (some say ours are hotter) but yours are longer. The Coolflow is meant to remove felt heat. Not cool the engine at all. What I did was to help cool the engine so you don't get to the point of needing the fan. I do believe removing the cat does the most for the heat issue.
    50+ Posts
    Feb 2021
    Newland, NC USA
    Quote Originally Posted by hydraglide View Post
    No problems at all.
    Really interested to hear how the heat shield liners work for you. I have a 21 with a stage 2 and love jugs with the hd coolflow fan.
    350+ Posts
    Aug 2020
    Monaca, Pa, USA
    Put one on my 2020 Tri glide. Live in Pa so not too extreme temps here. Run on those hot humid days in Aug. takes the edge off the heat. Be safe BK
    Dec 2021
    Woodridge,Il USA
    Quote Originally Posted by FirstTrike View Post
    I’ll let you know, hopefully soon.
    Hoping for good things!
    50+ Posts nokkon wud's Avatar
    Feb 2021
    Clearwater, Fl
    I put a Jaggs oil cooler with fan on my 13. It mounts on the down tube. I've done the tank lift, decat, tuner, floorboard extensions, and relocated the oil filter.
    I live west of you.
    Every little bit helps.
    The first 65 years of childhood is the hardest.
  11. #10
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    The cool flow fan is for reducing felt heat, not actual heat of the engine. And it is beneficial at reducing felt heat, just like the EITMS will reduce felt heat.
    What is better, for the rider, passenger and for the engine...is to reduce actual heat. Doing that will give you more power, a longer lasting engine, AND it reduces felt heat.
    Here's a video of low and no cost ways-
    www.DKCustom.com
  12. #11
    100+ Posts
    Apr 2022
    I did everything that they suggest that applied to the trike. Seems to work for me. OH. Except the airbox mod. I felt that would let hot air into the filter area and lowering the air density to the throttle body. Just my theory.
  13. #12
    Quote Originally Posted by SmittysTrike View Post
    On the contrary to the theory on the air box
    Getting rid of the ugly stock backing plate exposes the heads and cylinders to cooling from the air stream
    Using an external breather keeps the moisture robbing hot oil from entering the intake, helping to keep your engine running better for a longer time, while the new backing plate and opened up AC is pulling in a much better air flow
  1. Harley Davidson Cool Flow Fan P#26800128
    By windsurfed in forum Harley Tri Glide
    Last Post: 11-05-2020, 12:09 PM
  2. Tri Glide cool flow fan
    By El Lobo in forum Harley Tri Glide
    Last Post: 08-31-2020, 09:34 AM
  3. Anyone using the HD Cool Flow Fan to Reduce M8 Heat
    By Free Bird in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-09-2018, 10:05 AM
  4. HD Cool Flow Fan
    By sjambok in forum Harley Tri Glide
    Last Post: 05-18-2017, 02:25 PM
  5. Jims force flow fan
    By Paul692 in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-23-2016, 08:06 AM
