Likes Likes:  15
Thanks Thanks:  1
Results 1 to 15 of 15
Thread: Need Help
    Mar 2023
    Heath Springs, SC USA
    Default Need Help
    My park brake on my 2018 trike will not spring back. Im not sure how the spring goes on the pawl. Any help would be appreciated.
    Quote Originally Posted by Kenny_Carter View Post
    Kenny.......Welcome to Trike Talk......Im sure someone (Jack Klarich) will chime in soon with the schematics of the park brake....
    Hi Kenny, to Trike Talk
    Here is an exploded view of your parking brake
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Kenny, this is a common problem on the TriGlides.
    Try this: Press down on your rear brake pedal and listen to see if you hear the pawl "click" (clicks when engaged and also again when released). If you dont, press it down till firm, then slide your foot off the pedal and let it pop up. Do that several times and that will sometimes release the park brake. If it doesn't, you may have a bent/binding or broken pawl spring.(#7 on diagram) Visually inspect it and if you find that it damaged or broken, replace it.
    Name:  1Harleyparking brakeProb.jpg
    (moved thread to Harley TriGlide forum)
    Is your parking brake cable adjusted too tight?
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Welcome to Trike Talk Kenny!
    150+ Posts hydraglide's Avatar
    Dec 2021
    Woodridge,Il USA
    ^^^ This ^^^!
    I’ve had to do this trick occasionally if I accidentally ”baby it” when setting or releasing it initially.
    Let that parking brake pedal “fly” on release!
    Live Everyday Like It's Your Last... Because One Day It Will Be...
    2021 Billiard Red Tri-Glide • 1999 Ultra Classic - Stage 2, 6 Speed (Gone) • 1995 Softail Nostalgia (Gone) • 1977 Superglide - Chopped (Gone)
    • 1976 Liberty Edition Sportster (Gone) • 1949 Hydraglide Panhead - Fully Restored (Gone)
    Quote Originally Posted by hydraglide View Post
    ^^^ This ^^^!
    This works good for me when I do use the parking brake, easy put pressure on and let it fly off
    Lube all the moving parts including adjuster and all cables
    Grab the rear cable and give it a tug, is it tight? If so make changes to the adjustment and try again
  11. #10
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Dont forget to adjust the sensor air gap- at least check it.
  12. #11
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Quote Originally Posted by Old Road Dog View Post
    Michael, I am not familiar with the sensor air gap. Can you explain? Thanks
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
  13. #12
    Oct 2018
    Ramseur NC USA
    Quote Originally Posted by Rogue1 View Post
    I kinda figured.
  14. #13
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    I kinda figured.
    Just read this post Lad. Its part # 16 - looks like a cable with a blunt end. Theres a magnet in the stamped pedal. The gap between the two should be: 0.177- 0.197(4.5-5mm) disconnect sensor connector, loosen jamnut,turn sensor to adjust gap. Tighten jamnut 30-35 in.-lbs. Reconnect sensor connector. BTW the upstream side of the connector is where I tapped into to install a led lamp in the handlebar nacelle for the parking brake. The Dakota Digital MLX speedo dosnt support the parking brake lamp functon in 17- early 18 Freewheeler .
  15. #14
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    P.S.: the cable with the blunt end IS the sensor.
  16. #15
    Oct 2018
    Ramseur NC USA
    Thanks Michael. I've adjusted the brake several times and never paid attention to that. Thanks for the info.
  17. DKCustoms postbit
  1. Need major work and need recommendations. WHO
    By guatdoc in forum Honda Trikes
    Last Post: 01-30-2017, 05:15 PM
  2. Need help
    By redneckray in forum General Discussion
    Last Post: 05-31-2010, 01:03 PM
  3. Need Help
    By joelin5386 in forum Harley Trike Conversions
    Last Post: 05-29-2010, 06:00 AM
  4. Need some help with exhaust
    By johnchaparteguy in forum General Discussion
    Last Post: 03-18-2010, 12:38 PM
  5. Need your help
    By Terry Baker in forum General Discussion
    Last Post: 08-14-2009, 09:09 PM
