Likes Likes:  5
Thanks Thanks:  1
Results 1 to 6 of 6
Thread: M8 Shifter Shaft Bushing Video
    Default M8 Shifter Shaft Bushing Video
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Looks like a good idea to me before that bushing wears out and then requires a new inner primary cover to correct, but I didn't find any mention of it specifically fitting the FLRT.
    Quote Originally Posted by JTJersey View Post
    Same here, I sent them an E mail, waiting for a response
    My opinion, it will work on the FLRT, I already have my housing drilled and tapped with a grease fitting like the factory did in the past
    I lube the shaft/ bushing each oil change
    That said IMO this bushing is a plus compared to the stock set up, and I will be replacing mine soon, I do not need to purchase the tool they sell, I make my own from threaded stock and use a bushing driver piece from a set I have to push out the old one
    <br>
    Same here, I sent them an E mail, waiting for a response My opinion, it will work on the FLRT, I already have my housing drilled and tapped with a grease fitting like the factory did in the past I lube the shaft/ bushing each oil change That said IMO this bushing is a plus compared to the stock set up, and I will be replacing mine soon, I do not need to purchase the tool they sell, I make my own from threaded stock and use a bushing driver piece from a set I have to push out the old one
    Just did more research, The M8 bushing is different than the Twin Cams, ( Shorter)there for the M8 bushing they sell is the same for all M8 model touring including the Trikes
    H D OEM part number 1000139
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    The most damaging thing to a HD machine is the infamous power washer. Keep that friggen thing away from your bike/trike. If the damage is already done then theres no choice but replacement. If you were a wise cat and never used a PW on your HD and your shifter feels tight then just spray the bushing area with Boshield T9 and ride happy.
    Quote Originally Posted by Old Road Dog View Post
    Anyone using a pressure washer on a Harley does NOT deserve the Harley
  1. FIXED (sorta): Front shifter shaft lever pinch bolt snapped
    By emskee in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-02-2018, 04:59 PM
  2. Lower shock bushing - MotorTrike
    By GoldWingrGreg in forum Honda Trikes
    Last Post: 09-16-2017, 05:22 PM
  3. Rubber Bushing Lube
    By Jack Klarich in forum Harley Freewheeler / Road Glide 3
    Last Post: 06-27-2017, 08:08 AM
  4. Swing Arm Bushing upgrade
    By zoood in forum Harley Trike Conversions
    Last Post: 01-18-2013, 04:07 PM
  5. Replies: 1
    Last Post: 02-17-2012, 05:09 PM
