Results 1 to 3 of 3
Thread: Front tire question
    Mar 2023
    Citrus Springs
    Default Front tire question
    Just purchased a 2013 tri glide-it has a 130/60B 19 on the front-looking at original tire specs and it shows a MTB90 16.
    Anyone have thoughts on if this is ok or should I go back to original tire?
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    Welcome to Tike Talk.
    Sounds like you may have the Enforcer wheels on it. Stock is 16 and The enforcer wheel is 19. You should be good to go.
    2016 Tri Glide, More DK than HD. Just shut up and ride.
    Quote Originally Posted by Ezbagr View Post
    Yep the front tire/rim were changed possibly. You can even put a 21in under the stock fender. It changes the weight distribution by lifting the front so the steering is a little lighter. The profile is changed with the front being a little higher. I road with a 21 on the front of my 2013 TRI for 7 years and 60k miles and loved the look and the handling.
    The CVO trikes have the taller front wheel on them.
  1. Avon AV-71 Front Trike Tire - anyone using this tire???
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 02-16-2024, 04:24 PM
  2. Tire Pressure for MPA Front Tire
    By cScjhb in forum Honda Trikes
    Last Post: 09-13-2020, 12:11 PM
  3. tire size for rear tire on front? 2007 goldwing trike
  4. same ol front tire question
    By David H. in forum Harley Trike Conversions
    Last Post: 10-27-2013, 07:43 PM
  5. Oh, No! Another Front Tire Question
    By 87Trike1200 in forum Tires, Wheels, Brakes, Front End
    Last Post: 07-06-2013, 06:05 PM
